3850-24P ILPOWER-3-CONTROLLER-PORT-ERR:Controller port error, interface xyz : Power controller reports an unknown error
usmanali121
Helllo everyone,
I am receiving this error for an Aruba AP connected to Cisco 3850-24P Switch(Aruba AP225 and Aruba AP135 connected). There is no power in AP (working fine before at same port). Syslog flooded by these msgs,
Interface xyz: Power device detected:IEEE PD
Interface xyz: PD Removed
I tried following:
Checked the cable, found no problem in it.
Checked another AP135 at the same port. Same problem started with that AP too
Connected AP 135 at it's previous port but it did not come up. Same error for that port too
Checked Power Inline but status is "not connected"
Checked interface status. Showing "not connected"
All other APs working fine at the same time. But if I reconnect anyone, It goes to same error. And non-POE devices (Laptop) working fine over these ports.
Finally restarted the switch and everything was ok. I am unable to trace the actual problem. Please if somebody could help in this regard.
Thank you
Reza Sharifi
This could be a bug in the software that causes the controller dysfunction.  I would open a ticket with TAC and send them the logs for analyses.  If a software upgrade does not fix it, you may have to replace the hardware.
Thank you for your reply and support.
Leo Laohoo
Post the complete output to the following commands:
1. sh version;
2. sh interface <PORT> contr
Thanks for support. I guess this is a software bug, because it was not the problem of a any single port. Any port worked normal before disconnect and reconnect the POE device. As long as you reconnect your AP to the same port where it was working fine, it goes to same error. The output of SHOW VERSION is :
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.03.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 23-Sep-13 18:24 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
uptime is 19 hours, 37 minutes
Uptime for this control processor is 19 hours, 40 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Lanbase
License Type: Permanent
Next reload license Level: Lanbase
cisco WS-C3850-24P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCW1848C0CH
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 54:7c:69:18:34:00
Motherboard Assembly Number : 73-14441-10
Motherboard Serial Number : FOC18478DUU
Model Revision Number : T0
Motherboard Revision Number : A0
Model Number : WS-C3850-24P
System Serial Number :
Switch Ports Model SW Version SW Image Mode
1 32 WS-C3850-24P 03.02.03.SE cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
