3850/3650 - Traffic not running into correct queues - Egress QoS
lauresfrank
Dear Cisco-Community,
I have a question regarding egress queueing on a 3650 switch, Cisco IOS XE Release 3.3.3SE.
Ingress queuing works fine for phones (packets run into right classes), but when i look at the egress ports (uplink to core switch), the traffic does not appear to run into the right classes. whats is wrong or do i have a misunderstanding of the concept?
Config attached.
Thank you!
Uplink1:
#show policy-map interface GigabitEthernet1/1/1
  Service-policy output: egress_qos_marking
    queue stats for all priority classes:
      Queueing
      priority level 1
      (total drops) 0
      (bytes output) 45919
    Class-map: voice_payload_egress (match-any)    //NO MATCHES HERE. WHERE ARE MY EF VOICE PACKETS??
      0 packets
      Match:  dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: cos  5
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  precedence 5
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: Strict,
      Priority Level: 1
      police:
         rate 10 %
         rate 100000000 bps, burst 3125000 bytes
          conformed 0 bytes; actions:
            transmit
          exceeded 0 bytes; actions:
            drop
          conformed 0 bps, exceeded 0 bps
    Class-map: voice_control_egress (match-any)
      0 packets
      Match:  dscp cs3 (24)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: cos  3
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  precedence 3
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (total drops) 0
      (bytes output) 0
      bandwidth remaining 10%
      queue-buffers ratio 35
    Class-map: scavenger_egress (match-any)
      0 packets
      Match: cos  1
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  precedence 1
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  dscp cs1 (8)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (total drops) 0
      (bytes output) 0
      bandwidth remaining 20%
      queue-buffers ratio 5
    Class-map: class-default (match-any)
      186703 packets
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (total drops) 0
      (bytes output) 22937020
      bandwidth remaining 60%
      queue-buffers ratio 45
Uplink2:
GigabitEthernet1/1/2
      Queueing
      priority level 1
      (total drops) 0
      (bytes output) 1988045
      0 packets
      Match:  dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: cos  5
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  precedence 5
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: Strict,
      Priority Level: 1
      police:
         rate 10 %
            transmit
            drop
      0 packets
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match: cos  3
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  precedence 3
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (total drops) 0
      (bytes output) 0
      0 packets
      Match: cos  1
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  precedence 1
        0 packets, 0 bytes
        5 minute rate 0 bps
      Match:  dscp cs1 (8)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (total drops) 0
      (bytes output) 0
      200341 packets
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
      (total drops) 0
      (bytes output) 23138397
Client Port:
show policy-map interface Gi1/0/1
 GigabitEthernet1/0/1
  Service-policy input: edge_qos_marking
    Class-map: voice_payload (match-any) //HERE OKAY
      14166 packets
      Match: access-group name acl_voice_payload
        0 packets, 0 bytes
        5 minute rate 0 bps
      QoS Set
        dscp ef
    Class-map: voice_control (match-any)
      77 packets
      Match: access-group name acl_voice_control
        0 packets, 0 bytes
        5 minute rate 0 bps
      QoS Set
        dscp cs3
      80723 packets
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
      QoS Set
        dscp default
CSCO11659641
https://supportforums.cisco.com/discussion/10863531/acl-qos
