01-06-2015 08:13 PM - edited 03-07-2019 10:06 PM
Hi All,
Recently our customer has bought a new supervisor engine 8 for their catalyst 4507R-E chassis to replace the current supervisor engine 6l-e. The problem is when ever the chassis reload with the new supervisor engine 8, it appears a message stating some sort that this type of chassis is not supported by this supervisor engine thus the supervisor will shut down. When refer to the link http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_29676.html it stated there 1.The Cisco Catalyst 4507R-E Switch supports Supervisor Engine 8-E only on chassis that have hardware revision 2.0 or higher. Contact your Cisco customer service representative for more information. So then I have issued the show idprom chassis.
Chassis Idprom :
Common Block Signature = 0xabab
Common Block Version = 3
Common Block Length = 144
Common Block Checksum = 3909
Idprom Size = 256
Block Count = 4
FRU Major Type = 0x4001
FRU Minor Type = 52
OEM String = Cisco
Product Number = WS-C4507R-E
Serial Number = FOX1428H643
Part Number = 73-12778-01
Part Revision = C0
Manufacturing Deviation String = 0
Hardware Revision = 2.0
Top Assembly Number = 800-26494-03
Top Assembly Revision Number = A0
Power Consumption = 0
RMA Failure Code = 0 0 0 0
Chassis Block Signature = 0x4001
Chassis Block Version = 1
Chassis Block Length = 22
Chassis Block Checksum = 1167
Feature Bits = 0x0000000000000000
MAC Base = d0d0.fd85.15c0
MAC Count = 64
Clei Block Signature = 0x4601
Clei Block Version = 2
Clei Block Length = 26
Clei Block Checksum = 1142
Clei code string = IPMJ410BRB
Version ID string = V03
Clei ECI Number = 461486
SecSerialNum Block Signature = 0x4602
SecSerialNum Block Version = 1
SecSerialNum Block Length = 26
SecSerialNum Block Checksum = 773
SecSerialNum string = NWG1427026P
By right, this hardware revision is supported by the new supervisor engine 8. Idea anyone?
Thanks.
Solved! Go to Solution.
01-06-2015 08:51 PM
I think you need to upgrade the IOS-XE to 3.7.0E to be able to enable this feature.
Another thing, the Release Notes firmly states you need to upgrade the Bootstrap to SG5 in order to load 3.7.0E.
You can do this in just one reload with this process: Upgrading the Supervisor Engine ROMMON with Telnet
01-06-2015 08:37 PM
Are you using IOS-XE 3.7.0E?
01-06-2015 08:44 PM
Hi Leo,
During the ordering time, it was 3.3.1XO. I didn't managed to console the supervisor engine since it will keep reloading when the message stating chassis is not supported appears.
Thanks.
01-06-2015 08:51 PM
01-06-2015 08:57 PM
Hi Leo,
Thank you for pointing out the IOS version. I've managed to find the information at http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-37xe-4500e.html. The supervisor engine was ordered before the IOS 3.7.0E was released at Dec 10, 2014.
Again thanks.
01-06-2015 11:51 PM
Thank you very much for rating our posts. 🙂
