3850-48 Port Switch Reboots in ROMMON
johnmike
I have a 48 port 3850 switch that reboots into ROMMON every time the switch is recycled....can you please provide what the confreg settings should be. To get the switch to boot into full operational mode I have to console into the switch and run the Boot command.
Thank You
Leo Laohoo
Post the complete output to the command "sh boot" & "dir".
luis_cordova
Hi @johnmike ,
Check what this manual says:
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
The factory-default setting for the configuration register is 0x2102. This indicates that the router should attempt to load a Cisco IOS® software image from Flash memory and load the startup configuration with a console speed of 9600 baud.
It tells you how to make the register change as well.
