DHCP process on management port of Catalyst 9200 (16.10.1) causes crash
tristanr
Switch(config)#int gi0/0
Switch(config-if)#ip address dhcp
Switch(config-if)#no shut
Switch(config-if)#exit
Switch(config)#ip http client source-interface gi0/0
Switch(config)#ip tftp source-interface gi0/0
Switch(config)#end
Switch#
*May  8 15:06:22.238: %SYS-5-CONFIG_I: Configured from console by console
Exception to IOS Thread:
Frame pointer 0x7F345F0B00, PC = 0x23BDB50
UNIX-EXT-SIGNAL: Segmentation fault(11), Process = DHCP Client
-Traceback= 1#b50a241b49c298e433d02fff02683d12  :400000+12F2344 :400000+12F1CE8 iosd_crb_ngwc_unix:7F6B964000+5EB54 linux-vdso:7F7F89A000+510 :400000+1FBDB50 :400000+3735208 :400000+3738F68 :400000+442B530 :400000+39B1D1C :400000+39319F0 :400000+39318D4 :400000+3935754 :400000+373BCC8 :400000+2407F78
Fastpath Thread backtrace:
-Traceback= 1#b50a241b49c298e433d02fff02683d12  iosd_crb_ngwc_unix:7F6B964000+5EC2C linux-vdso:7F7F89A000+510 c:7F6B7E3000+C7124 iosd_crb_ngwc_unix:7F6B964000+3C840 prelib:7F7F7FF000+3A0C pthread:7F6B741000+6FD8 c:7F6B7E3000+C6F90
Packet Thread backtrace:
-Traceback= 1#b50a241b49c298e433d02fff02683d12  iosd_crb_ngwc_unix:7F6B964000+5EC2C linux-vdso:7F7F89A000+510 c:7F6B7E3000+C7124 iosd_crb_ngwc_unix:7F6B964000+5C318 prelib:7F7F7FF000+3A0C pthread:7F6B741000+6FD8 c:7F6B7E3000+C6F90
Auxiliary Thread backtrace:
-Traceback= 1#b50a241b49c298e433d02fff02683d12  iosd_crb_ngwc_unix:7F6B964000+5EC2C linux-vdso:7F7F89A000+510 pthread:7F6B741000+D478 iosd_crb_ngwc_unix:7F6B964000+64D44 prelib:7F7F7FF000+3A0C pthread:7F6B741000+6FD8 c:7F6B7E3000+C6F90
R0 = D0D0D0D0D0D0D0D  R1 = 00000000 R2 = 7F6BA78CB0  R3 = 00000000
R4 = 7F645AC000  R5 = 00002563  R6 = 00000000  R7 = 00002563
R8 = D0D0D0D0D0D0D0D  R9 = 00000000
R10 = 0C81EDB0  R11 = B86D1000000000  R12 = 00000000  R13 = 0000021B
R14 = 0000021B  R15 = 1D82000000000000  R16 = 7F6BA6AC88  R17 = 7F6B8B6198
R18 = 071A847B  R19 = 0C831000  R20 = D0D0D0D0D0D0D0D  R21 = 7F2F875B48
R22 = 7F3602B0B8  R23 = 7F3602B0B8  R24 = 00000000  R25 = 7F33109760
R26 = 00000001  R27 = 7F31880BE8  R28 = 7F3187F830  R29 = 7F345F0B00
R30 = 03B35208  SP = 7F345F0A20
LR = 03B35208  PC = 023BDB50
Writing crashinfo to crashinfo:crashinfo_RP_00_00_20190508-150631-UTC
Buffered messages:
tate to down
*May  8 14:51:16.620: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN10/2, changed state to up
*May  8 14:51:17.044: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*May  8 14:51:17.652: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*May  8 14:51:26.872: %HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
*May  8 14:51:37.345: %SYS-5-RESTART: System restarted --
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.10.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 14-Nov-18 06:35 by mcpre
*May  8 14:51:39.100: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/1, changed state to down
*May  8 14:51:39.106: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/2, changed state to down
*May  8 14:51:39.107: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/3, changed state to down
*May  8 14:51:39.107: %LINK-3-UPDOWN: Interface GigabitEthernet1/1/4, changed state to down
*May  8 14:51:39.107: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
*May  8 14:51:39.107: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/2, changed state to down
*May  8 14:51:39.107: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/3, changed state to down
*May  8 14:51:39.107: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/4, changed state to down
*May  8 14:51:39.336: %LINK-3-UPDOWN: Interface Vlan1, changed state to up
*May  8 14:51:40.103: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/1, changed state to down
*May  8 14:51:40.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to down
*May  8 14:51:40.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/3, changed state to down
*May  8 14:51:40.108: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/4, changed state to down
*May  8 14:51:40.108: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
*May  8 14:51:40.108: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to down
*May  8 14:51:40.108: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/3, changed state to down
*May  8 14:51:40.108: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to down
*May  8 14:51:57.587: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*May  8 14:51:57.973: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*May  8 14:51:58.000: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
*May  8 14:52:08.351: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified.  Issue "write memory" to save new IOS PKI configuration
*May  8 14:52:08.361: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
*May  8 14:52:08.362: %SMART_LIC-5-COMM_RESTORED: Communications with the Cisco Smart Software Manager or satellite restored
*May  8 14:52:20.019: %PLATFORM_PM-6-FRULINK_INSERTED: 4x10G uplink module inserted in the switch 1 slot 1
*May  8 15:05:35.414: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*May  8 15:05:36.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*May  8 15:06:09.512: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-61240685 has been generated or imported by crypto-engine
*May  8 15:06:09.515: %SSH-5-ENABLED: SSH 1.99 has been enabled
*May  8 15:06:09.643: %PKI-4-NOCONFIGAUTOSAVE: Configuration was modified.  Issue "write memory" to save new IOS PKI configuration
*May  8 15:06:09.759: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-61240685.server has been generated or imported by crypto-engine
*May  8 15:06:38.270: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*May  8 15:06:31.510: %CRB_EVENT-3-CRB_RT_ERROR: CRB Runtime Exception: attempted negative int -> ptr cast (0xB86D1000000000)
-Traceback= 1#b50a241b49c298e433d02fff02683d12   :400000+367694C :400000+1736354 iosd_crb_ngwc_unix:7F6B964000+D03EC :400000+13006F0 :400000+12F1A4C :400000+12F1D00 iosd_crb_ngwc_unix:7F6B964000+5EB54 ld-linux-aarch64:7F7F86A000+30510 :400000+1FBDB50 :400000+3735208 :400000+3738F68 :400000+442B530 :400000+39B1D1C :400000+39319F0 :400000+39318D4 :400000+3935754 :400000+373BCC8 :400000+2407F78
IOSD RP: 2972 messages not written to btrace log fileMay  8 15:07:29.807: %PMAN-3-PROCHOLDDOWN: R0/0: pman: The process linux_iosd-image has been helddown (rc 139)
May  8 15:07:29.999: %PMAN-0-PROCFAILCRIT: R0/0: pvp: A critical process linux_iosd_image has failed (rc 139)
May  8 15:07:30.281: %PMAN-3-RELOAD_SYSTEM: R0/0: pvp: Reloading: Peer switch is not standby ready. System will be reloaded
Chassis 1 reloading, reason - Reload command
May  8 15:07:32.843: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
May  8 15:07:35.717: %PMAN-5-EXITACTION: R0/0: pvp: Process mMay  8 15:07:47.704: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/system-report_1_20190508-150736-UTC.tar.gz (size: 22159 KB) generated
May  8 15:07:50.142: %PMAN-5-EXITACTION: C0/0: pvp: Process manager is exiting:
watchdog watchdog0: watchdog did not stop!
reboot: Restarting system
Reza Sharifi
Traceback messages are caused by IOS Bugs. Open a ticket with Cisco. They will most likely recommend an upgrade.
Leo Laohoo
Never use 16.10.1.
Upgrade to 16.11.1 and try again.
