3850 AUX port
pwwiddicombe
Level 9
Level 9
I noticed that, on a 3850 switch, that a "sh line" shows I have an AUX port on the system.  However, physically I don't actually see it, only the console port.  Does it actually exist, or is it a repurposing of the "con" port?
I ask, as It would be handy to have an aux port, as on a router, to do reverse telnet to other devices being set up.  It appears you can't use the console port to do reverse telnet.
Reza Sharifi
The 3850 series and most other platforms like 3650, 3750x, 3560x, etc.. don't come with AUX port.
You would need some sort of terminal server.
That's what I was thinking.  but on the 3850, when I do a "sh lin", I get this...
#sh line
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
     0 CTY              -    -      -    -    -      0       0     0/0       -
     1 AUX   9600/9600  -    -      -    -    -      0       0     0/0       -
*    2 VTY              -    -      -    -    -     36       0     0/0       -
     3 VTY              -    -      -    -    -      7       0     0/0       -
     4 VTY              -    -      -    -    -      0       0     0/0       -
     5 VTY              -    -      -    -    -      0       0     0/0       -
     6 VTY              -    -      -    -    -      0       0     0/0       -
     7 VTY              -    -      -    -    -      0       0     0/0       -
So, is this a vestige of router code that doesn't actually exist?  I have this in the config...
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password 7 1511021F0725
 login local
line vty 5 15
 login
Correct. I tried it on another 3850 and that has the same thing.  So, I guess its just leftover from other platforms as there is no actual AUX port.  Only OOB and Con.
Ronald Kaestner
Community Member
My assumption is, that is the USB port (the big one, not the micro-USB). My hope is to use it with an mircoUSB<-->USB cable for reverse telnet connection. This would be very nice.
