3850 bundle mode to insall
bluesea2010
Level 5
Level 5
I want to change from  bundle mode to install
below  is the list of dir flash:
61954 -rwx 2097152 Nov 17 2021 11:39:21 +03:00 nvram_config
61956 -rw- 305290172 Jul 20 2018 19:49:46 +03:00 cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin
61957 drwx 4096 Dec 30 2019 20:02:29 +03:00 dc_profile_dir
61963 -rw- 1248 Aug 3 2015 09:10:08 +03:00 packages.conf
12 drwx 4096 Aug 3 2015 09:10:37 +03:00 mnt
77446 -rw- 79122052 Aug 3 2015 09:10:04 +03:00 cat3k_caa-base.SPA.03.03.05SE.pkg
77447 -rw- 6521532 Aug 3 2015 09:10:04 +03:00 cat3k_caa-drivers.SPA.03.03.05SE.pkg
77448 -rw- 34530288 Aug 3 2015 09:10:04 +03:00 cat3k_caa-infra.SPA.03.03.05SE.pkg
77449 -rw- 34846028 Aug 3 2015 09:10:04 +03:00 cat3k_caa-iosd-universalk9.SPA.150-1.EZ5.pkg
77450 -rw- 25170832 Aug 3 2015 09:10:04 +03:00 cat3k_caa-platform.SPA.03.03.05SE.pkg
77451 -rw- 77456192 Aug 3 2015 09:10:05 +03:00 cat3k_caa-wcm.SPA.10.1.150.0.pkg
61959 -rwx 7276 Jul 17 2021 10:31:12 +03:00 vlan.dat
So  I want to  run the below command
software expand file flash:/cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin
before expanding,  I want to clean up old files .How can I do that ?
22 Replies 22
Reza Sharifi
Follow this link to convert from bundle to install mode.
https://www.reddit.com/r/Cisco/comments/7gg04m/cisco_3850_convert_from_bundle_to_install_mode/
Leo Laohoo
software install file flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin new force verb on-reboot
Use the command above to start the Install Mode process of unpacking/extracting the package files from the BIN file.
After the process completes, check to make sure the time & date stamp of packages.conf file.  If the time and date is not the same as the time and dates of the new package files, check the content of the package file:
more flash:packages.conf | begin for NOVA
The package files inside the packages.conf file should point to the new version.
Next, use the "sh boot" command to make sure the boot variable string is pointing to the packages.conf file.  In the "sh boot" output, make sure "Manual Boot" is "NO".
Reboot when everything looks good.
After the reboot, clean up the flash (or else the switch will nag).
NOTE:  See attachment for better instructions (including pictures).
Hi @Leo Laohoo  and @Reza Sharifi
The switch was  a stack member .I removed it from the stack.The plan is to  create another stack
I tried the above   and getting "I tried the below and getting "% Switch 5 must be running installed software to perform this operation"
And also how to  remove the old  " 1248 Aug 03 2015 06:10:08.0000000000 +00:00 packages.conf"
If I extract this will be over writen ?
Post the complete output to the following commands:
  • dir
  • sh boot
  • sh version
Please see the below
Directory of flash:/
sh boot
Switch 5
Current Boot Variables:
BOOT variable = flash:packages.conf;   (This one I change  but did not save )
Boot Variables on next reload:
BOOT variable = flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin;
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
sh version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.08.E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 22-Jan-18 05:56 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
sw1 uptime is 22 hours, 5 minutes
Uptime for this control processor is 22 hours, 8 minutes
System returned to ROM by Power Failure at 20:13:27 UTC Mon Dec 30 2019
System image file is "flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin"
Last reload reason: Power Failure
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-48P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCY2011D0XL
3 Virtual Ethernet interfaces
312 Gigabit Ethernet interfaces
24 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 88:90:8d:19:36:00
Motherboard Assembly Number : 73-14442-10
Motherboard Serial Number : FCY2011D0XL
Model Revision Number : S0
Motherboard Revision Number : A0
Model Number : WS-C3850-48P
System Serial Number : FCY2011D0XL
Switch Ports Model SW Version SW Image Mode
* 5 56 WS-C3850-48P 03.06.08.E cat3k_caa-universalk9 BUNDLE
Configuration register is 0x102
Leo Laohoo
So here is the steps:
1.  software install file flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin new force verb on-reboot
2.  Check the packages files are pointed to the correct version -- more flash:packages.conf | begin for NOVA
3.  Remove the old boot variable statement and make sure the boot variable is pointed to "packages.conf".
conf t
 no boo system switch all
 boot system flash flash:packages.conf
end
wr
4.  Save the config.
5.  Reboot the switch.
Again, refer to my document -- Cisco 3850: IOS-XE/Firmware Upgrade
Hi @Leo Laohoo
As i said earlier in the post the following commands  software install file flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin new force verb on-reboot giving the below   "% Switch 5 must be running installed software to perform this operation""
and it is not proceeding the installation
@bluesea2010 wrote:
Hi @Leo Laohoo
Is this switch in a stack?
hI @Leo Laohoo
this switch was in a stack ,I removed from the stack .
It still holds  the stack information
sh switch
Switch/Stack Mac Address : 8890.8d19.3600 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 0000.0000.0000 0 0 Provisioned
2 Member 0000.0000.0000 0 0 Provisioned
3 Member 0000.0000.0000 0 0 Provisioned
4 Member 0000.0000.0000 0 0 Provisioned
*5 Active 8890.8d19.3600 11 V04 Ready
6 Member 0000.0000.0000 0 0 Provisioned
Since the switch was removed from the stack, you need to un-provision the switch first because right now the switch still thinks it is #5.
Reza is right.  It must be some kind of a bug.
Do the following
no switch 1 provision
no switch 2 provision
no switch 3 provision
no switch 4 provision
no switch 6 provision
switch 5 renumber 1
And then reboot the switch (it should boot up as switch #1).
And re-run the command again.
Now getting the below
% Switch 1 must be running installed software to perform this operation
Change the boot string to point to the packages.conf.
Boot that and re-run the command.
Thanks for your support always .
i exapnded the bin file
"software expand file flash:/cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin"
Preparing expand operation ...
[1]: Expanding bundle flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin
[1]: Copying package files
[1]: A different version of provisioning file packages.conf already exists in flash:.
The provisioning file from the expanded bundle will be saved as
flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.conf
[1]: Package files copied
[1]: Finished expanding bundle flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.bin
61954 -rwx 2097152 Nov 18 2021 13:42:26 +03:00 nvram_config
61957 drwx 4096 Nov 18 2021 13:41:38 +03:00 dc_profile_dir
61964 -rw- 83298692 Nov 18 2021 13:53:13 +03:00 cat3k_caa-base.SPA.03.06.08E.pkg
61965 -rw- 3949504 Nov 18 2021 13:53:25 +03:00 cat3k_caa-drivers.SPA.03.06.08E.pkg
61966 -rw- 33811696 Nov 18 2021 13:53:15 +03:00 cat3k_caa-infra.SPA.03.06.08E.pkg
61963 -rw- 1248 Aug 3 2015 09:10:08 +03:00 packages.conf (this is still the old file )
61967 -rw- 43109956 Nov 18 2021 13:53:19 +03:00 cat3k_caa-iosd-universalk9.SPA.152-2.E8.pkg
61968 -rw- 28447888 Nov 18 2021 13:53:17 +03:00 cat3k_caa-platform.SPA.03.06.08E.pkg
61962 -rw- 1251 Nov 18 2021 13:53:44 +03:00 cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.conf
61969 -rw- 112667612 Nov 18 2021 13:53:25 +03:00 cat3k_caa-wcm-ldpe.SPA.10.2.180.0.pkg
can I set the boot variable flash:cat3k_caa-universalk9ldpe.SPA.03.06.08.E.152-2.E8.conf
Please advise
