3850 Fiber Dropping packets on Single Mode Duplex Fiber SFP/Link
metuckness
Hi All,
I have a 3805-XS switch:
Switch Ports Model SW Version SW Image Mode
* 1 34 WS-C3850-24XS 03.07.04E cat3k_caa-universalk9 INSTALL
I am installing an Axis Thermal Camera and I am using the AXIS T8612 SFP Module LC.SX in the camera and the Cisco GLC-LH-SMD. But I am having an issue with connectivity. I will get connectivity for about a minute, then drop packets, repeat.
I read on the forums it could be my firmware, but I am not sure how to confirm. My issue is, I am about to put it up on a 380ft tower and I would like to have an idea the equipment, at least, is compatible so I don't have to go back up on the tower to replace.
The SFP is plugged into port 13.
Any suggestions?
CONFIG:
F24#sh run
Building configuration...
Current configuration : 7894 bytes
! Last configuration change at 00:19:09 UTC Sat Nov 23 2019
version 15.2
no service pad
service password-encryption
service compress-config
hostname  F24
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$ITeG$IA GBgNmZIP6J.
enable password 7 06575F724 5544
username admin privilege 15 password 7 03285 0F
username mtuckness privilege 15 secret 5 $1$0wxz$d fOVK0SZ81ylF/
aaa new-model
aaa session-id common
switch 1 provision ws-c3850-24xs
coap http enable
ip routing
qos queue-softmax-multiplier 100
crypto pki trustpoint TP-self-signed-428772
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-428772
revocation-check none
rsakeypair TP-self-signed-428772
crypto pki certificate chain TP-self-signed-428772
certificate self-signed 02
3082022B 30820194 A0030201   300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34323837 37323230 3033301E 170D3137 30393238 32333537
31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 32383737
32323030 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100DF6B 2A3FE75C 6CE57D14 EC874E2B B77656F3 D862D0E7 3E0569DE BAA305FA
3AA8AF6D 80348F03 B0E867CA C3A0234B CFB53765 1FF4C71E 250840AE 1AEFFF96
CC1882F9 0B087F7E F2B35A26   9205BB30 F086E5AC AE13A512 3D3A1F10
A111E8E1 52D04E30 A0915F24 5E2D5A68 CB7532C5 B89AE321 40488EE6 3EB76107
B7B10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14DA8873 74DF0B63 A845B02E 272EBA5C 7F5A497F 9F301D06
03551D0E 04160414 DA887374 DF0B63A8 45B02E27 2EBA5C7F 5A497F9F 300D0609
2A864886 F70D0101 05050003 818100DD 6C99228A 20EBCFBB 7DFDF29C 2AC88450
D3ABCCD6 03801231 6E351FA8 251D3EFC 22ECF0D7 FB0F309A 1FEF5C13 BA01FEF4
ED3E7223 A8D65100 99F0D3BF EA42D101 6B72553E 229FB38D 0A71CA96 89D3FC91
A20CD9A6 AA790AA1 4A40DBCC ED1A175C FA0E7201 AE0EF5F9 037C1E7E CBBFC2DE
4A70C0F0 A346F0A0 12BF91A3 A04858
quit
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface Port-channel1
description 20GB LACP Team VEEAM Backup SRV
switchport access vlan 1xx
switchport mode access
interface Port-channel3
description Uplink to 3750 Stack PAgP
switchport trunk allowed vlan 10,1xx,1xx,172
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface TenGigabitEthernet1/0/3
description
interface TenGigabitEthernet1/0/4
description
interface TenGigabitEthernet1/0/5
interface TenGigabitEthernet1/0/6
description DIS-POS-01
interface TenGigabitEthernet1/0/7
channel-group 3 mode desirable non-silent
spanning-tree portfast trunk
interface TenGigabitEthernet1/0/8
interface TenGigabitEthernet1/0/9
description NETAPP TEAM 1
switchport trunk allowed vlan 1xx,1xx
shutdown
interface TenGigabitEthernet1/0/10
shutdown
interface TenGigabitEthernet1/0/11
shutdown
interface TenGigabitEthernet1/0/12
shutdown
interface TenGigabitEthernet1/0/13
interface TenGigabitEthernet1/0/14
description LaCP Team to Veeam Backup Server
channel-group 1 mode active
interface TenGigabitEthernet1/0/15
interface TenGigabitEthernet1/0/16
interface TenGigabitEthernet1/0/17
interface TenGigabitEthernet1/0/18
interface TenGigabitEthernet1/0/19
interface TenGigabitEthernet1/0/20
interface TenGigabitEthernet1/0/21
interface TenGigabitEthernet1/0/22
interface TenGigabitEthernet1/0/23
interface TenGigabitEthernet1/0/24
description x
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface Vlan1
no ip address
shutdown
interface Vlan10
description PFS
ip address 10.10.xx.2xx 255.255.255.0
ip helper-address 10.10.10.2
interface Vlan1xx
description  Patch Subnet
ip address 192.168.1xx.2xx 255.255.255.0
ip helper-address 192.168.1xx.2xx
interface Vlan1xx
description Admin Subnet
interface Vlan172
description 172 VLAN
ip address 172.16.1.247 255.255.255.0
router eigrp 100
network 10.0.0.0 0.0.0.255
network 172.16.0.0
network 192.168.1xx.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1xx.x
snmp-server community
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
session-timeout 30
password 7 062A0A35414B00
line vty 5 15
password 7 022A014F060306
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
Reza Sharifi
SX is short haul and LH is long haul. It seems that you are using LH on the Cisco switch and SX on the camera. Can you verify?
Also, have you replaced/tested the fiber patch?
Sorry, that was on me. I posted the wrong model of the Axis SFP. I do have the Axis Communications T8611 Small Form-Factor Pluggable Single-Mode LC.LX Fiber Module in the camera.
I think it might be an insufficient power issue. The DC power supply I have it 4.5 amp, and it looks like the camera, with the IR illuminators and thermal imaging, can use up to 9.5 amps. So, I need to get a 9.5 or probably an 11.5 amp power supply to attempt and see if it helps because I have replaced modules, patch, and everything except for an IOS update on the switch. I plan to do that, but it requires a scheduled downtime and not something I am tackling during the holidays.
I just figured out it might be the PS, but I have to order a larger one and wait till it gets here.
Leo Laohoo
It is not (yet) the firmware & I agree with Reza. The SFPs at both ends are not of the same wavelength.
