3850 in ROMMON
supernova_6
Hoping for some help as I'm stuck in rommon mode on a switch after converting from Install Mode to Bundle Mode.
I followed the article, (see file2 attached)
I forgot to put the name of the .bin file on the end....although upon further inspection I don't have a .bin file. I only have a set of .pkg files, (see file1 attached). I before realizing, I rebooted the switch and now I'm stuck in rommon mode. DOH!
I have tried to flash_init and setting the switch to boot from flash but with no success, my bootloader version is CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.58
Help please guys!
Seb Rupik
try:
boot flash:/packages.conf
Don't forget to update the bootvar once you load IOS-XE up!
cheers,
Seb.
Seb Rupik
try:
cheers,
Seb.
that's done it, thank you.
I've just followed the "Converting from Bundle Mode to Install Mode" and updated the bootvar as suggested which now reads...
Current Boot Variables:
BOOT variable = flash:packages.conf;
Boot Variables on next reload:
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
