3850 memory
S891
Level 2
Level 2
I am seeing consistently across all my 3850 access switches that the io memory is very low. Is this a software bug or is it normal? Even when we upgraded to a new IOS version it did not change.
3850-SW# sh mem
                    Head              Total(b)           Used(b)         Free(b)            Lowest(b)            Largest(b)
Processor   FF880F7010   873745296    268936788    604808508      601715584        603255996
lsmpi_io     FF834301A8    6295128        6294304          824                824                    412
brselzer
What version of code are you running now? This is probably going to depend heavily on what features you are running. You might want to open a support ticket to have them check it out if you don't want to post your configuration here.
Hope that helps!
-Bradley Selzer
CCIE# 60833
NetworKing16
We are running mostly 3850 Checked a few of our switches a 24 port unit in our I.T office with a couple devices on it. And a stack of three switches handling about 100 nodes. They both showed similar specs.
System memory : 3937308K total, 1437892K used, 2499416K free, 222060K kernel r eserved
Lowest(b) : 1888043704
Total(K) Used(K) Free(K)
Process 3937308 1437892 2499416
Config 0 0 0
I do not really know why your units would have issue no issue seen on version  03.06.05E.
If I had to guess I would be looking at spanning tree and broadcast storms or something like that that may cause massive loads and issues on your switch(es).
