3850 not able to save config 03.03.02.SE
marc.groenen
I have a stack of 2x 3850's(WS-C3850-48T) running flash:cat3k_caa-universalk9.SPA.03.03.02.SE.150-1.EZ2.bin.
A few day's a go i had a hanging console session after executing a "sh run | i  " command, i wasnt able to clear the session.
This resulted in the following problem:
NLXXX-MER-CI3850-01#wr
startup-config file open failed (Device or resource busy)
I cant save the configuration.
The device is working OK and i can change the configuration but there is no way of saving it.
So after googling for a while i decided to reboot the stack after that everything was OK.
I just did a "sh run int" will being logging in using SSH and again the session hangs.
Now i was able to clear the session but still the same issue:
Attached is a 'sh ver"
2 Accepted Solutions
InayathUlla Sharieff
Its due to bug. The concern is as a result of the NVRAM locking. The trigger condition for this concern is the presence of KRON configurations on the 3850.
 By any chance have you  configured Kron?
Inayath
Plz rate all usefull posts.
Hello Marc,
This behaviour is due to a bug that is know to be fixed in release 03.03.03SE using an EEM script to replace the kron job.
  • CSCtk68692
The startup-config and running-config on the controller become unavailable after running a kron job.
The workaround is to reload the controller. To avoid this condition, use Embedded Event Manager (EEM) with the timer event to schedule the required task.
Inayath
Yes i have a small kron configuration script active in the configuration.
I will remove the kron script and then i will have to reboot the stack again.
But since i cant write the config to startup it will be there after the reboot so i will then have to quickly remove it i guess :) or is there a workaround ?
Hello Marc,
  • CSCtk68692
