3850 poe+ switch problem with IOS need to load new ios flash read-only mode
hi,
Having problem booting 3850 switch, trying to load IOS from switch: prompt. says flash: file system is read-only. how can i load IOS on this.
This switch was part of the stack of 4.
Pls. help
6 Replies 6
Diana Karolina Rojas
You can do a Hard Update from the rommon mode taking the file from a TFTP server, you have to use the following commands:
rommon 3 > set
    PS1=rommon ! >
    IP_ADDRESS=172.18.16.76 (the ip you want to configure on your switch to reach the tftp)
    IP_SUBNET_MASK=255.255.255.192
    DEFAULT_GATEWAY=172.18.16.65 (If you connect the TFTP direct to the switch so you have to write here the TFTP ip)
    TFTP_SERVER=172.18.16.2 (tftp ip address)
    TFTP_FILE=quake/rel22_Jan_16/c2600-i-mz (IOS name)
Take into acount that all the configuration will be lost.
--Do not forget to rate useful post---
This is 3850, it is going into "switch:" (i think, ROMMON mode in 3850)
switch:
switch: set
ABNORMAL_RESET_COUNT=0
AUTOREBOOT_RESTORE=1
BOOT=flash:packages.conf
BSI=0
BYPASS_STARTUP_CONFIG=1
CFG_MODEL_NUM=WS-C3850-48F-E
CLEI_CODE_NUMBER=IPMW700ARB
DEFAULT_ROUTER=192.0.2.122
ECI_CODE_NUMBER=466864
IP_ADDR=192.0.2.123/255.255.255.0
LINUX_COREMASK=15
MAC_ADDR=88:90:8D:71:9F:00
MANUAL_BOOT=yes
MODEL_NUM=WS-C3850-48P
MODEL_REVISION_NUM=S0
MOTHERBOARD_ASSEMBLY_NUM=73-14442-10
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FOC19126A4E
POE1_ASSEMBLY_NUM=73-14095-01
POE1_REVISION_NUM=B0
POE1_SERIAL_NUM=FOC191160L8
POE2_ASSEMBLY_NUM=73-14095-01
POE2_REVISION_NUM=B0
POE2_SERIAL_NUM=FOC191160L1
RANDOM_NUM=1572356125
RECOVERY_BUNDLE=sda9:cat3k_caa-recovery.bin
STKPWR_ASSEMBLY_NUM=73-11956-08
STKPWR_REVISION_NUM=B0
STKPWR_SERIAL_NUM=FOC191200AJ
SWITCH_NUMBER=4
SWITCH_PRIORITY=12
SYSTEM_SERIAL_NUM=FCW1912C16E
TAN_NUM=800-37564-03
TAN_REVISION_NUMBER=B0
TEMPLATE=advanced
TERMLINES=0
USB_ASSEMBLY_NUM=73-12923-05
USB_REVISION_NUM=C0
USB_SERIAL_NUM=FOC19122U1Z
VERSION_ID=V04
switch: copy tftp://192.0.2.122/cat3k_caa-universalk9.SPA.03.07.01.E.152-3.E1.bin flash:
flash:cat3k_caa-universalk9.SPA.03.07.01.E.152-3.E1.bin: read only file system
above is the output of set. flash is giving read only file system. how can we make it read write file system
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
bs[3]: (read-only)
flash[18]: (read-only)
usbflash0[19]: (read-write)
tftp[20]: (read-write)
switch:
Ok, try to recover the switch using this command:
switch: emergency-install tftp://192.168.1.2/cat3k_caa-universalk9.SPA.03.06.05.E.152-2.E5.bin
Tell me the result when you do this.
at the beginning tried emergency-install but still not loading the IOS. seems flash is set to read only mode. unable to format also.
switch: dir
bs[3]: (read-only)
switch:
brian0613m
Try with the IOS in a USB an also use the commands
