01-17-2017 07:24 AM - edited 03-08-2019 08:56 AM
we are searching QoS Features on Catalyst 3850 16.3.2 Denali. They are documented in Configuration Guide.
show platform qos is missing:
c3850#show platform ?
atm-cdvt Display platform atm cdvt value
authentication Show switch auth info
conditions Show conditional debug info
diag Diagnostic information
flow Show Platform flow for FNF Information
frontend-controller Show frontend controller info
hardware Show platform hardware information
host-access-table host access table info
idbman Interface Descriptor Block management information
integrity Boot integrity
oir Ng3k OIR
packet-trace CPP packet trace information
pm Show Platform Port Manager Info
resources Show platform resources information
software Show platform software information
sudi Secure identity
| Output modifiers
<cr>
Is there a specific way to check QoS queues ?
br Kerstin
01-17-2017 02:14 PM
Hi --
I believe that platform has moved to the standard MQC methodology. You should be able to use "show policy-map interface gix/x".
PSC
01-24-2017 06:31 AM
thank you very much. I have found the commands now.
br Kerstin
01-24-2017 05:58 AM
I was searching for the same as you & finally found they replaced the syntax
you should be able to find the old show platform qos commands using the new
For more information, command reference describes the options
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-3/command_reference/b_163_consolidated_3650_cr/b_163_consolidated_3650_cr_chapter_01101.html#wp2788251940
Gilles
