3850 Stack and Stack Priority
alex.roth
Level 3
Level 3
Question regarding a Cisco 3850 & Stack .
I´ve two 3850 switches stacked.
sh switch
Switch/Stack Mac Address : c025.5cb9.1b80 - Local Mac Address
Mac persistency wait time: Indefinite
                                             H/W   Current
Switch#   Role    Mac Address     Priority Version  State
*1       Active   c025.5cb9.1b80     1      J0      Ready
2       Standby  c025.5cb7.c480     1      J0      Ready
Now I will change the priority from switch 1 from 1 to  15 but I can´t do this:
(config)#switch 1 ?
  provision  Configure Switch provision / offline confi NMTSL3CORE1
I can´t use the command : switch 1 priority  15 as exmaple . Why ?
Thanks for help.
Cheers
Alex,
Get out of configuration mode.  Switch priority can be done in enable or EXEC mode.
Go here.
9 Replies 9
Leo Laohoo
If you can't use the command "switch 1 priority 15" then show us the syntax and the error message.
See below :
(config)#switch 1 pr
provision
and
(config)#switch 1 pri?
% Unrecognized command Thx
Thx
Can you post the complete output to the command "sh version"?
See below :
sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.01SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Dec-13 10:15 by prod_rel_team
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
NMTSL3CORE1 uptime is 2 hours, 57 minutes
Uptime for this control processor is 2 hours, 59 minutes
System returned to ROM by reload at 11:53:48 CET Mon Dec 16 2013
System image file is "flash:packages.conf"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-24P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1737X0T4
4 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : c0:25:5c:b9:1b:80
Model Revision Number              : J0
Motherboard Revision Number        : C0
Model Number                       : WS-C3850-24P
Switch Ports Model              SW Version        SW Image              Mode
*    1 32    WS-C3850-24P       03.03.01SE        cat3k_caa-universalk9 INSTALL
     2 32    WS-C3850-24P       03.03.01SE        cat3k_caa-universalk9 INSTALL
Switch 02
Switch uptime                      : 58 minutes
Base Ethernet MAC Address          : c0:25:5c:b7:c4:80
Configuration register is 0x102
Cheers
Alex,
Go here.
OK, this solution is easy , ... double checked the docu and this correct . It´s just habit to use the conf t mode,
Many thanks ,
Someone re-invented the wheel, Alex.
Thanks for taking the time to rate our posts.
you should configure it under privileged mode.
SW0701#switch 2 priority 15
john - You are right .
