3850 stack power 5 switches not forming ring
hmc250000
We have a 5 switch 3850 stack and I'm trying to get the stack power to work but no luck so far. I'm following this document.
https://208.74.205.244/t5/networking-documents/how-to-form-a-catalyst-3850-data-stack-and-power-stack/ta-p/3156083/page/2
Does it matter which end of the cable (yellow and green) is plugged in where? I have it plugged in so that the yellow mark on the cable is at the top end and the green mark at the bottom of the cables.
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48T 03.07.04E cat3k_caa-universalk9 INSTALL
2 56 WS-C3850-48T 03.07.04E cat3k_caa-universalk9 INSTALL
3 56 WS-C3850-48T 03.07.04E cat3k_caa-universalk9 INSTALL
4 34 WS-C3850-24XS 03.07.04E cat3k_caa-universalk9 INSTALL
5 34 WS-C3850-24XS 03.07.04E cat3k_caa-universalk9 INSTALL
#sh stack-power
Power Stack Stack Stack Total Rsvd Alloc Unused Num Num
Name Mode Topolgy Pwr(W) Pwr(W) Pwr(W) Pwr(W) SW PS
Powerstack-1 SP-PS Stndaln 0 0 0 0 0 0
Powerstack-12 SP-PS Stndaln 715 305 410 0 1 1
Powerstack-13 SP-PS Ring 1050 210 840 0 3 3
#sh stack-power det
Power stack name: Powerstack-1
Stack mode: Power sharing
Stack topology: Standalone
Switch 4:
Power budget: 410
Power allocated: 410
Low port priority value: 22
High port priority value: 13
Switch priority value: 4
Port 1 status: Shut
Port 2 status: Shut
Neighbor on port 1: 0000.0000.0000
Neighbor on port 2: 0000.0000.0000
Power stack name: Powerstack-12
Switch 5:
Power budget: 410
Port 1 status: Not connected
Port 2 status: Not connected
Power stack name: Powerstack-13
Stack topology: Ring
Switch 2:
Power budget: 280
Power allocated: 280
Port 1 status: Connected
Port 2 status: Connected
Neighbor on port 1: Switch 3 - 00a2.8986.5700
Neighbor on port 2: Switch 1 - 00a2.8986.8780
Switch 3:
Power budget: 280
Low port priority value: 20
High port priority value: 11
Switch priority value: 2
Neighbor on port 1: Switch 1 - 00a2.8986.8780
Neighbor on port 2: Switch 2 - 00a2.898d.a500
Switch 1:
Power budget: 280
Low port priority value: 21
High port priority value: 12
Switch priority value: 3
Neighbor on port 1: Switch 2 - 00a2.898d.a500
Neighbor on port 2: Switch 3 - 00a2.8986.5700
example
#stack-power switch 1 port 1 ?
disable Disable power stack port
enable Enable power stack port
and yes i would do 2 rings if your using stack-power as redundancy
7 Replies 7
pieterh
Hi there I notice this in your output:
Switch 1, 2, 3
Power budget: 280 each
and
Switch 4, 5
Power budget: 410 each
do switch 4 and 5 have redundant power supplies themselves? (show inventory)
All 5 switches have 1 power supply. Switch 4 and 5 have a 715 W power supply.
#sh in
*Jan 14 07:50:30.017: %SYS-5-CONFIG_I: Configured from console by administrator on consoleventory
NAME: "c38xx Stack", DESCR: "c38xx Stack"
PID: WS-C3850-48T , VID: V07 , SN: FCW2027F0ZT
NAME: "Switch 1", DESCR: "WS-C3850-48T-S"
PID: WS-C3850-48T-S , VID: V07 , SN: FCW2027F0ZT
NAME: "StackPort1/1", DESCR: "StackPort1/1"
PID: STACK-T1-50CM , VID: V01 , SN: LCC2022G4AM
NAME: "StackPort1/2", DESCR: "StackPort1/2"
PID: STACK-T1-50CM , VID: V01 , SN: LCC2022G4AE
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-350WAC , VID: V01 , SN: ART2026F0HU
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "4x1G Uplink Module"
PID: C3850-NM-4-1G , VID: V01 , SN: FOC20214N6R
NAME: "Gi1/1/3", DESCR: "1000BaseLX SFP"
PID: GLC-LH-SMD , VID: V01 , SN: FNS1847164X
NAME: "Switch 2", DESCR: "WS-C3850-48T-S"
PID: WS-C3850-48T-S , VID: V07 , SN: FCW2027D10F
NAME: "StackPort2/1", DESCR: "StackPort2/1"
PID: STACK-T1-50CM , VID: V01 , SN: LCC2022G4E4
NAME: "StackPort2/2", DESCR: "StackPort2/2"
NAME: "Switch 2 - Power Supply A", DESCR: "Switch 2 - Power Supply A"
PID: PWR-C1-350WAC , VID: V01 , SN: ART2026F0HY
NAME: "Switch 2 FRU Uplink Module 1", DESCR: "4x1G Uplink Module"
PID: C3850-NM-4-1G , VID: V01 , SN: FOC20214NQ2
NAME: "Switch 3", DESCR: "WS-C3850-48T-S"
PID: WS-C3850-48T-S , VID: V07 , SN: FOC2027U1Q2
NAME: "StackPort3/1", DESCR: "StackPort3/1"
PID: STACK-T1-50CM , VID: V01 , SN: LCC2022G4EM
NAME: "StackPort3/2", DESCR: "StackPort3/2"
NAME: "Switch 3 - Power Supply A", DESCR: "Switch 3 - Power Supply A"
PID: PWR-C1-350WAC , VID: V01 , SN: ART2026F0HX
NAME: "Switch 3 FRU Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"
PID: C3850-NM-2-10G , VID: V01 , SN: FOC19261BLQ
NAME: "Te3/1/4", DESCR: "1000BaseLX SFP"
PID: , VID: , SN: AGS1008A0KE
NAME: "Switch 4", DESCR: "WS-C3850-24XS-S"
PID: WS-C3850-24XS-S , VID: V02 , SN: FCW2221C01N
NAME: "StackPort4/1", DESCR: "StackPort4/1"
PID: STACK-T1-50CM , VID: V01 , SN: LCC2120GAQ2
NAME: "StackPort4/2", DESCR: "StackPort4/2"
NAME: "Switch 4 - Power Supply A", DESCR: "Switch 4 - Power Supply A"
PID: PWR-C1-715WAC , VID: V02 , SN: DCA2215G2GJ
NAME: "Switch 5", DESCR: "WS-C3850-24XS-S"
PID: WS-C3850-24XS-S , VID: V02 , SN: FOC2237L120
NAME: "StackPort5/1", DESCR: "StackPort5/1"
NAME: "StackPort5/2", DESCR: "StackPort5/2"
NAME: "Switch 5 - Power Supply A", DESCR: "Switch 5 - Power Supply A"
PID: PWR-C1-715WAC , VID: V02 , SN: DCA2230G12C
Deepak Kumar
As per your picture, the ring is not closed. Please close the ring as recommended.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Well should there not be 2 rings actually? Because only up to 4 switches are supported in a power stack? THe way this is wired I think there should be one ring of 3 switches and another ring of 2. Correct me if I'm wrong.
And I noticed and think the problem here might be that the power stack ports on switch 4 are shut. Any idea how to unshut?
Switch 4:
Power budget: 410
Port 1 status: Shut
Port 2 status: Shut
example
Found it.
Did this 3850#stack-power switch 1 port 1 enable
3850#stack-power switch 1 port 2 enable
Now showing rings:
#sh stack-power
Powerstack-1 SP-PS Ring 715 305 410 0 1 1
This is now working correct right?
yes looks ok but always confirm with and show switch detail
show switch stack-ports
Switch# Port1 Port2
1 OK OK
2 OK OK
3 OK OK
