Stackwise Standby removed
Adnan Khan
Level 6
Level 6
I have two C9407 and configured in stackwise virtual. When I removed SVL and Dual active cables then Standby switch goes in recovery mode and in show switch output it shows as removed. When I connect the cables back then standby switch does not join the stack and remain as removed in show switch output. Any idea what could be the issue?
Mark Malone
Hi Adnan
what way have you physically set this up , did you follow the guide , this issue has come up before please see this post it may help
https://community.cisco.com/t5/switching/cisco-9407-svl-testing-procedure/td-p/3869104
