3850 Switch IP Address Issue
I have ran into an issue with an VLAN SVI IP Address on a 3850-12S switch. The current IP is set to 172.20.3.1/21. There is another 3850 switch upstream of this switch and a 2960X downstream. I have a server plugged into the upstream switch that resides on a different VLAN. My issue is from the server (10.102.0.175/24) I am unable to ping the switch IP 172.20.3.1. However, If I go to the 3850 switch that the server is plugged into I am able to ping the IP even with it sourced from the interface that is in the 10.102.0.0/24 network. From the server I am able to ping 172.20.3.3 which is the IP assigned to the 2960X switch. If i change the 3850 switch IP from 172.20.3.1 to another IP in the subnet such as 172.20.3.100, then I am able to ping the switch from the server. If I revert back to the .1 address communication is once again lost from the server. I have verified there are no duplicate IPs on the network. verified ARP entries are correct, verified routing, verified subnet masks and default gateways are all correct, and also verified there are no ACLs acting on the traffic. There are also no firewalls in play. I have attached a drawing which illustrates the small network. There is something about using the .1 address on the 3850. Any suggestions are greatly appreciated.
6 Replies 6
VIvanov
Sounds really odd.  check sh ip arp  on the .254 when 3850-12s is .100 (im guessing standby is on somewhere if thats not it theres a typo somewhere or a bug)
balaji.bandi
Looks bizzared issue.
can you post the 3850-12sconfig, and show ip arp on all the switches.
Tracertoute from server  to 172.30.3.3
BB
Along with above config/output request. Please share the routing output from the 3850
sh ip route 172.20.3.1
are you able to ping 172.20.3.1 from 2960x??
I will see what information I can provide as far as configurations. Customer has strict security policies in place so it is difficult to get copies of the configurations. All pings work fine from 2960. The only think that is not working is pinging from the 3850 to the server and server to 3850 when using the .1 address.
Here is what I am able to provide for the two switches. I am working on trying to collect the arp entries and a possible trace route.
Switch 1:
Server is connected to port Gi1/0/3
Switch 2 is connected to port Gi1/1/2
no ip source-route
ip routing
no ip gratuitous-arps
interface GigabitEthernet1/0/3
switchport access vlan 3
switchport mode access
speed 1000
duplex full
spanning-tree portfast
interface GigabitEthernet1/1/2
no switchport
ip address 172.20.3.254 255.255.248.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan251
ip address 10.102.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip default-gateway 172.20.8.254
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.20.8.254
ip ssh version 2
Switch 2:
Switch 3 connected to port Gi1/0/1
Switch 1 connected to port Gi1/0/11
no ip source-route
interface GigabitEthernet1/0/1
switchport access vlan 2
interface GigabitEthernet1/0/11
interface Vlan201
ip address 172.20.3.1 255.255.248.0
no ip route-cache
ip default-gateway 172.20.3.254
no ip classless
no ip http server
ip ssh version 2
High level this seems to wrong here :
ip default-gateway 172.20.8.254   <-- remove this
no ip http server
ip route 0.0.0.0 0.0.0.0 172.20.8.254  <-- change this to 172.20.3.254
BB
