3850 Usb slot usage
Hi, I have a 3850 switch with a USB slot on the front that I want to use for a code upgrade. With nothing plugged into the front USB drive slot, I do a dir usbflash0: and it lists files? How can that be if nothing is inserted. A show usbflash0: shows nothing. When I plug a 2 gb USB (FAT16) stick in the drive, the same results. I see files from somewhere but not from my USB drive. So the front USB slot is not reading my drive.  If I issue a Dir command it returns directory of usflash0: so that must be the front usb slot. I can see a log message when I insert and remove the usbflash drive on the console. Thank you.
Mark Malone
what files is it listing when its not plugged in , are they from flash or where ?
sounds like bug anyway , that's not normal if that's what's happening  , you can see usb files when theres nothing connected to it ...
what version code are you on
nothing is plugged into the usb slot. (cat3k_caa-universalk9.16.05.01a.SPA.bin)
Directory of usbflash0:/
24818  drwx             2440  Jun 13 2017 11:36:02 -04:00  webui
14679  drwx               60  Jun 13 2017 11:35:56 -04:00  rpid
20054  drwx               60  Jun 13 2017 11:35:55 -04:00  fifo
17251  drwx               40  Jun 13 2017 11:35:55 -04:00  stage
14672  drwx               40  Jun 13 2017 11:35:54 -04:00  firmware
 7495  drwx               80  Jun 13 2017 11:35:52 -04:00  opt
 9374  drwx              640  Jun 13 2017 11:35:54 -04:00  lua
10354  drwx               80  Jun 13 2017 11:35:51 -04:00  3pa
 4015  -rwx                6  Jun 13 2017 11:35:50 -04:00  bootflash
 4013  drwx               60  Jun 13 2017 11:35:50 -04:00  ngwc_config
 4012  -rwx               17  Jun 13 2017 11:35:50 -04:00  install
 4011  -rwx                8  Jun 13 2017 11:35:50 -04:00  drec0
 4010  -rwx                8  Jun 13 2017 11:35:50 -04:00  ucode0
 4009  -rwx                8  Jun 13 2017 11:35:50 -04:00  obfl0
 4008  -rwx                8  Jun 13 2017 11:35:50 -04:00  lic1
 4007  -rwx                8  Jun 13 2017 11:35:50 -04:00  lic0
 4006  -rwx               13  Jun 13 2017 11:35:50 -04:00  flash
 4005  -rwx                8  Jun 13 2017 11:35:50 -04:00  crashinfo
 4004  -rwx               10  Jun 13 2017 11:35:50 -04:00  usb1
 4002  -rwx               10  Jun 13 2017 11:35:50 -04:00  usb0
 4000  -rwx               10  Jun 13 2017 11:35:50 -04:00  disk0
 3999  -rwx               10  Jun 13 2017 11:35:50 -04:00  config
 3998  -rwx               13  Jun 13 2017 11:35:50 -04:00  harddisk
 3960  drwx               60  Jun 13 2017 11:36:18 -04:00  tftp
 3959  drwx              100  Jun 13 2017 11:35:50 -04:00  misc
 3958  drwx               40  Jun 13 2017 11:35:50 -04:00  auto
 4913  drwx              180  Jun 13 2017 12:08:08 -04:00  mnt
 5540  drwx             1360  Jun 13 2017 12:26:36 -04:00  tmp
 5481  drwx              280  Jun 13 2017 11:35:50 -04:00  var
  288  drwx              120  Jun 13 2017 11:35:50 -04:00  run
  279  drwx                0   --- -- ---- --:--:-- -----  proc
  278  drwx                0  Jun 13 2017 11:35:50 -04:00  sys
   79  -rwx            55784   Mar 9 2017 08:32:40 -05:00  explode-common
 3580  -rwx             1886  Dec 14 2016 04:07:11 -05:00  verify_packages.sh
 3579  -rwx            17533  Jan 20 2016 18:53:49 -05:00  explode
 3578  -rwx             3894  Sep 21 2015 11:25:34 -04:00  rmon_vars.sh
 3577  -rwx             3341   Dec 7 2016 07:18:06 -05:00  cpld_util.sh
 3576  -rwx             1422   Apr 4 2014 09:33:13 -04:00  rommon_to_env
 3575  -rwx           109784  Feb 27 2017 01:53:22 -05:00  common
 3574  -rwx             8760  Jan 17 2017 19:23:39 -05:00  mount_packages.sh
 3573  -rw-              149  May 30 2017 04:56:34 -04:00  .image_info
 3572  -rw-              443  May 30 2017 04:56:34 -04:00  .pkginfo
 3571  -rw-              124  May 30 2017 04:56:34 -04:00  .pkgset
 3570  -rwx               20  May 30 2017 04:56:30 -04:00  init
 3568  drwx              100  May 30 2017 04:56:30 -04:00  guestshell
 3564  drwx             1460  Jun 13 2017 11:35:51 -04:00  bin
 3563  drwx             1320  Jun 13 2017 11:35:51 -04:00  lib64
 3560  drwx             1160  Jun 13 2017 11:35:51 -04:00  sbin
 3473  drwx              140  May 30 2017 04:56:30 -04:00  lib
 3452  drwx             1100  Jun 13 2017 11:36:05 -04:00  etc
 3425  drwx              240  Jun 13 2017 11:35:59 -04:00  usr
 3424  drwx               40  May 24 2009 16:33:51 -04:00  root
 3422  drwx            13620  Jun 13 2017 12:26:04 -04:00  dev
that looks like its reading the system files , personally if it was my switch I would upgrade off the version that's not right , if its still doing that after I would speak to TAC maybe get it RMA if there is something up the hardware
