3925 with 48 port switch module infinite loop
one10wilson
Hello all,
I have a 3925 Router with a 48 port switch module (part number SM-D-ES3G-48-P).  I have no problem accessing the 3925 Router, but when I go into the 48 port, I get an error that reads
Error Hardware not supported by firmware.
Try loading a newer software instead.
System Resetting...
I know that the wrong IOS is installed on the switch, but the problem is that this is an endless loop.  The switch resets then comes back to the same error.  I was wondering if anyone out there knows how to get the switch out of this loop so that I can load the correct IOS.  Thanks everyone in advance.
Lee
Peter Paluch
Hello Lee,
Do you believe this document could be helpful?
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#wp1920363
Best regards,
Peter
