Bookmark
Subscribe
1242
3945 and NM-16ESW module
Documentation says that NM-16ESW is supported in 3945 router with the NM module adapter, but I am not able to choose NM-16ESW module for 3945 router in Cisco Configuration Tool.
Can anyone clarify whether or not this module is supported?
And one more question - does new  L3 enchanced etherswitch service modules support shaping and llq on its ports?
Collin Clark
That is no longer an orderable part number. The 3945 (probably all G2's) only support the Enhanced EtherSwitch.
Hope it helps.
Well, that's a pity. As I can understand all this new etherswitch modules act as separate devices with separate configs, and there are no modules similar to NM-16ESW (with the ability to turn on the routed port on it and share the same config with router). Am I right?
Not sure about ES2 etherswitch modules though, perhaps they function exatly as I need.
