09-19-2013 05:00 AM - edited 03-07-2019 03:33 PM
Hi all,
If by mistake, at the time of getting license from Cisco, we provide serial number of another router and not the one that is supposed to use that license, then what is needed to be done to correct this mistake.
I will appreciate if someone can refer me a doc also which highlights this issue
Solved! Go to Solution.
09-19-2013 05:02 AM
Send an email to licensing@cisco.com and provide the correct serial number (so they can generate a new code for you) and the wrong serial number (so they can remove it from the list).
09-19-2013 05:43 AM
Good point. Don't have one. This is my method and it works. :)
Sent from Cisco Technical Support Nintendo App
09-19-2013 05:02 AM
09-19-2013 05:08 AM
Sir, please refer me any document so i can read more about it
09-19-2013 05:43 AM
09-19-2013 06:32 AM
Still thanks alot Sir
