3D CAD Model (.stp) for WS-C3650-24TD-S
joshua.rothe
Trying to find a 3D CAD model (.stp file is fine, any dumb solid model works) for WS-C3650 series of switches. Tech support basically said they couldn't help me and to contact a partner which was not very helpful, hoping someone here can point me in the right direction :) need this file for use in a larger assembly of a rack we are building. I'll even take a basic technical drawing if there are no 3D cad files.
Reza Sharifi
Hi Joshua,
Unfortunately, there is no CAD 3D file available for Cisco equipment, however you maybe able to use Visio, convert it to PDF and send it to your vendor.
