4 port and 8 port switch module in Cisco 1941 router
brobinb
Hi there,
My questions is can a 4 port PoE switch module (EHWIC-4ESG-P) and a 8 port switch module (EHWIC-D-8ESG) be used at the same time in a Cisco 1941 router?
Thanks in advanced.
Robin
Reza Sharifi
No, the EHWIC-D-8ESG is double-wide and so you can only put one double-wide or 2 single-wide.
From the data sheet:
Two integrated EHWIC slots are available on the  Cisco 1941 for flexible configurations for support of two modules: One  double wide HWIC-D or single wide EHWIC/HWIC module and a second single  wide E-HIC/HWIC module are supported.
see table-3 in this link:
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/data_sheet_c78_556319.html
