Policy Based Routing and Next Hop IPs
Chris Pohlad-Thomas
I notice when working on my PBRs that it will let you set multiple next-hop IPs. Are these for redundancy I assume? For example, if I have it setup like this:
set ip next-hop 4.2.2.1 4.2.2.2
will it try the 4.2.2.1 and if the interface that is connected to doesn't work it will try 4.2.2.2?
mfurnival
Level 4
Level 4
Hi Chris,
"If the interface associated with the first next hop specified with the set ip next-hop command is down, the optionally specified IP addresses are tried in turn"
From this document:
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfindp2.html#wp1020776
mfurnival
Level 4
Level 4
Hi Chris,
From this document:
Thanks for the info! I might also think about using an SLA type configuration like in this document:
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
Hello chris,
FYI - for resiliency with PBR, if the next hop  interfaces are unreachable the policy will still try to forward  traffic based on the match statements and start arping for the next hop  address.
Applying the set ip next-hp verify-availability command  into the polciy will make the router do a cdp lookup for the next-hop address  before policy routing and if its not found the router will route normal instead
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
