4/port Serial Async/Sync (HWIC 4 A/S)
ashleyreed4218
I have a Cisco 1811 with a 4/port Serial Async/Sync (HWIC 4 A/S) and another 2 port A/S serial wic.
My router seems to have a problem reading the 4/port card. I did some research and it looks like there shouldn't be a compatibility issue.
Anyone have any ideas?
Thank you in advance,
Ashley
It is definitely not a compatibility issue. Not hardware at least. Post the output of
show diag
show inv
and upgrading your IOS you should be fine. The IOS you have in is quite old and possibly still works better with the old WIC daughter cards.
Hope this helps
Alessio
7 Replies 7
show diag
show inv
Hope this helps
Alessio
Thanks Alessio:
Router#sh diag
Slot 0:
        C2811 Motherboard with 2FE and integrated VPN Port ad         apter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC114952T0
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26920-04
        Board Revision           : C0
        Deviation Number         : 0
        Fab Version              : 04
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20071210
        Chassis Serial Number    : FCZ1201717C
        Chassis MAC Address      : 001e.7aa4.2128
        MAC Address block size   : 24
        CLEI Code                : COM7R00ARA
        Product (FRU) Number     : CISCO2811
        Part Number              : 73-10258-05
        Version Identifier       : V05
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 31 34 39 35 32 54 30          40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 43          30
          0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04          00
          0x30: 09 87 83 01 32 43 2A C2 8B 46 43 5A 31 32 30          31
          0x40: 37 31 37 43 C3 06 00 1E 7A A4 21 28 43 00 18          C6
          0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49          53
          0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28          12
          0x70: 05 89 56 30 35 00 D9 02 40 C1 FF FF FF FF FF          FF
        WIC Slot 0:
        Serial 2A/S (12in1)
        Hardware revision 1.0           Board revision B0
        Serial number     33976684      Part number    800-03         182-02
        Test history      0x0           RMA number     00-00-         00
        Connector type    PCI
        EEPROM format version 1
          0x20: 01 13 01 00 02 06 71 6C 50 0C 6E 02 00 00 00          00
          0x30: 58 00 00 00 05 08 28 00 FF FF FF FF FF FF FF          FF
        WIC Slot 1:
        Unknown WAN daughter card
        Part Number              : 73-9117-05
        Board Revision           : A1
        Fab Version              : 05
        PCB Serial Number        : FOC11494R4V
        RMA History              : 00
        Top Assy. Part Number    : 800-23789-01
        Connector Type           : 01
        Product (FRU) Number     : HWIC-4A/S
        Version Identifier       : V01
        CLEI Code                : CNUIAC9AAA
          0x00: 04 FF 40 04 44 41 01 00 82 49 23 9D 05 42 41 31
          0x10: 88 00 00 00 00 02 05 C1 8B 46 4F 43 31 31 34 39
          0x20: 34 52 34 56 03 00 81 00 00 00 00 04 00 C0 46 03
          0x30: 20 00 5C ED 01 05 01 CB 94 48 57 49 43 2D 34 41
          0x40: 2F 53 20 20 20 20 20 20 20 20 20 20 20 89 56 30
          0x50: 31 20 D9 02 40 C1 C6 8A 43 4E 55 49 41 43 39 41
          0x60: 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Router#sh inv
Router#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis, Hw Serial#: FCZ1201717C, Hw Revision: 52.57"
PID: CISCO2811         , VID: V05, SN: FCZ1201717C
NAME: "c2811 Motherboard with 2FE and integrated VPN", DESCR: "c2811 Motherboard with 2FE and integrated VPN"
PID: CISCO2811         , VID: V05, SN: FOC114952T0
NAME: "WAN Interface Card - Serial 2A/S", DESCR: "WAN Interface Card - Serial 2A/S"
, SN: 33976684
WIC Slot 1:
Take out an reinstall the card in WIC Slot 1 and do the test again. Power off the router when you do this.
I would reccomend to upgrade the IOS and nothing more. It is a problem with the card i believe, not with the router.
Hope this helps
Alessio
Yea, same issue:
Router#sh diag
Slot 0:
        C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
        Board Revision           : C0
        Fab Version              : 04
        RMA History              : 00
        Processor type           : 87
        WIC Slot 1:
        Board Revision           : A1
        Fab Version              : 05
        RMA History              : 00
        Connector Type           : 01
Router# sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.3(8)T6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Wed 29-Dec-04 15:07 by hqluong
ROM: System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System image file is "flash:c2800nm-ipbase-mz.123-8.T6.bin"
Cisco 2811 (revision 53.50) with 253952K/8192K bytes of memory.
Processor board ID FCZ1201717C
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
But check this out, I put the card in another 2811 I have, and I think it is the same IOS, it reads it perfectly?
Router#sh start
Using 1240 out of 245752 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging buffered 4096 informational
no aaa new-model
resource policy
no network-clock-participate wic 0
ip subnet-zero
ip cef
no ip domain lookup
interface FastEthernet0/0
ip address 192.168.72.5 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.73.6 255.255.255.0
ip access-group 10 in
duplex auto
speed auto
interface Serial0/0/0
no ip address
clock rate 128000
dce-terminal-timing-enable
interface Serial0/0/1
no ip address
shutdown
clock rate 128000
interface Serial0/0/2
no ip address
shutdown
clock rate 128000
interface Serial0/0/3
no ip address
shutdown
clock rate 128000
ip classless
ip http server
logging 192.168.72.6
access-list 10 permit 10.20.30.40 log
access-list 10 deny   any log
access-list 10 permit 10.20.30.0 0.0.0.255
access-list 10 permit 10.20.20.0 0.0.0.255 log
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 02:36 by alnguyen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-ipbase-mz.124-3g.bin"
Cisco 2811 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FTX1128F05Z
4 Low-speed serial(sync/async) interfaces
Router#sh diag
Slot 0:
        PCB Serial Number        : FOC11246BKD
        Top Assy. Part Number    : 800-26920-03
        Board Revision           : A0
        Fab Version              : 03
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20070624
        Chassis Serial Number    : FTX1128F05Z
        Chassis MAC Address      : 001c.586a.4598
        CLEI Code                : COM7C00ARA
        Part Number              : 73-10258-04
        Version Identifier       : V04
          0x00: 04 FF C1 8B 46 4F 43 31 31 32 34 36 42 4B 44 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 03 42 41 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 40 E0 C2 8B 46 54 58 31 31 32 38
          0x40: 46 30 35 5A C3 06 00 1C 58 6A 45 98 43 00 18 C6
          0x50: 8A 43 4F 4D 37 43 30 30 41 52 41 CB 8F 43 49 53
          0x70: 04 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
        WIC Slot 0:
        HWIC Serial 4A/S daughter card
        Board Revision           : A1
        Fab Version              : 05
        RMA History              : 00
        Connector Type           : 01
I take it back what I said, the other router has 12.4 IOS, so it is the IOS12.3 and the hwic?
Hi Ashley,
i would say so. Upgrade it to the same IOS you have tested now and let me know
Alessio
