4 SFP Ports for a Switch
syed.shameem1
Hi All,
I have a got a requirement where a 24 Port Switch should have 4 SFP's and all 4 should be used at a time, So I've chosen " WS-C2960S-24TS-L"
The transeiver should be GLC-LH-SM, so kindly let me no whether I would be able to use all 4 ports at a time or not.
Thanks & Regards,
Shameem Syed
nkarthikeyan
Level 7
Level 7
Hi Shameem,
Yes. You can use all the ports @ a same time.
Cisco Catalyst 2960S-24TS-L
24 Ethernet 10/100/1000 ports
4 One Gigabit Ethernet SFP ports
And if you need all single mode connectivity for the uplinks also you can use the same without any issue using GLC-LH-SM
Please do rate if the given information helps.
By
Karthik
Leo Laohoo
Yes you can.  I have this model in my network.
