4331 Transceiver Not Supported/Not Compatible
I have kind of a weird issue going on.  I currently have an 1921 with a GLC-LH-SM that reaches out to another building and currently working great.
I'm trying to migrate connections over to a 4331, but whenever I insert a GLC-LH-SM transceiver into g0/0/2 (the dedicated SFP) I get an error stating %TRANSCEIVER-3-NOT_SUPPORTED: SIP0: iomd:  Detected for transceiver module in Gigabitethernet0/0/2, module disabled.
I ran the service unsupported-transceiver command, and am now receiving the error %TRANSCEIVER-3-NOT_COMPATIBLE: SIP0: iomd:  Detected for transceiver module in Gigabitethernet0/0/2, module disabled.
This is a Cisco branded gbic, and I am on the 3.16.02S code and the transceiver shows that it is on the supported list - so I don't know what is going on.  Has anyone else had this problem on this router?
25 Replies 25
Yeah, I have the same problem with a 4331 router and a glc-sx-mmd running 3.16.02 IOS.
My 4331 does not complain about it being not_compatible, usually that happens only when you run a old IOS version..
funny thing is that its working on another 4351 router that I have, same IOS version, same SFP type.
I am currently creating a TAC case via my Cisco partner, so hopefully within a few days I will have a fix to the problem.. I will let you know what the outcome was..
Esben
I managed to establish the reason for my problem, but I'm still unsure of the root cause. So, I tried a newer (3 years old) GLC-SX-MM in the same SFP port, and my original 4431 Router immediately recognises the adapter. When I use an older (6 years old) GLC-SX-MM in the same SFP port, my 4431 Router does not recognise it, but the older adapter works OK on an older Router (3845). Therefore there must be a difference between older and newer adaptors of the same type....in that my Cisco 4431 only likes the newer GLC-SX-MM. Cisco TAC have yet to explain to me the difference between the older and newer GLC-SX-MM, or to identify why this occurs, but at least I have a solution by using the newer GLC-SX-MM. So, in your case a brand new GLC-SX-MM might help.
Im using a brand new GLC-SX-MMD module, so slightly different..
The router actually sees the module correctly in the Ge0/0/0 slot, but not in the Ge0/0/2 slot?!?
TAC just informed me that they are going to RMA the router, not sure if its going to work, but whatever they think is best.. ;-)
I will let you all know how it goes.. Perhaps if I find time, I will try and setup another 4331 router from stock and see if that works, but I am a little pressed on time right now.
Esben
software change fixed it for us , zx model sfps , glcts and glxsx had issues with all of them on different software typesnonly some would work on  certain versions  , the one software version they all worked on was .....asr1001x-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
n.bokhar1
i have the same issue with glc-t and glc-te i have bought several sfps and none of them work i changed my software to the latest version still haven't got any results has anybody managed to make it work?
or can anyone call cisco tac?
faraj
in cisco GE 2010 .I have problem to re install new SFP lx. in g0/1 or g0/0 ... msg appear unknown media type.
despite i used same SFP with different cisco ,and its work correctly
Try command:
Remove the optic and re-install.
This worked for me onisr4400-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin
Before command:
*Aug 2 21:53:16.160: %TRANSCEIVER-3-NOT_SUPPORTED:iomd: Detected for transceiver module in Gigabitethernet0/0/3,
*Aug 2 21:57:54.349: %TRANSCEIVER-6-REMOVED:iomd: Transceiver module removed from Gigabitethernet0/0/3
After command:
*Aug 2 21:58:12.341: %TRANSCEIVER-6-INSERTED:iomd: transceiver module inserted in Gigabitethernet0/0/3
Interfce cam up and is working fine.
Kindly. Thanx alot. but i tried these command. nothing happend
which transceiver do you have exactly ? Check the compatibility matrix linked below first and make sure you meet the requirements:
https://tmgmatrix.cisco.com/?si=4331
kazama747
Hi All
I have read through all the post, but it seems like there is still no clear solution.
Does anyone know if GLC-LH-SMD SFP is not supported on GE0/0/2 port of ISR4331/K9?
It sounds like only the GLC-TE (RJ-45) SFP is supported on GE0/0/2 port of ISR4331/K9.
Jin
Is there any one resolved this issue ? our isr4331 Gi0/0/2 port still down status, it also insert GLC-SX-MMD and replace it multi times...
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
