4500 PM Callback Process
csco10387876
Anyone can tell me what this process is and what it does and how to troubleshoot high cpu peak due to this process ?
ankbhasi
Hi Friend,
Can you confirm if you have voice vlans configured on some ports and if yes then do you also have trunk configuration on thise ports and if yes than can you please paste the the config for those ports?
Ankur
I don't have voice vlan configured on the port but we do have a IPT solution with another brand of phone so that our port config looks like :
switchport trunk native vlan 311
switchport trunk allowed vlan 311,321
switchport mode trunk
switchport port-security maximum 2
switchport port-security aging time 5
switchport port-security aging type inactivity
no logging event link-status
spanning-tree portfast trunk
Hi Friend,
Can you confirm which sup you have installed in your cat4k and which IOS you are running on the same?
Also is it possible for you to remove the trunk config from the ports where you have IPT solution connected and configure voice vlan and access vlan for data?
PM callback" process is an internal process dealing with Port Management, I mean, this process manages the ports via an internal mechanism.
Ankur
hi,
Cat sup 2+ ios : 12.2(31)SGA1
We cannot remove the trunk config as it would shutdown the IPT 😉
the voice vlan config doesn't work for us sadly.
