frame relay
carl_townshend
Hi all, when setting up frame relay, first is there a max bandwidth of 2 megabits per circuit, and also if the pvc say id pvc855, would the other end use 558, or is this not always the case ??
nambi_gct
the pvc number can be different on the two sides.There is a mapping done in the frame relay switch.bandwidth of the pvc depends upon your agreement with the ISP.bandwidth command need not always represent the actual bandwidth.
