4500 Port-Channel Bug - Suggestions
hmartinez05
I have a strange issue, that I'm have not been able to nail down, I'll do the best I can to explain this.
Background
We have a P2P link between 2 switches, HQ and Data Center. On the DC side, we have configured port channels to our VM environment, an example of the configuration per port is below.
int TenGigabitEthernet5/5
switchport trunk native vlan 999
switchport allowed vlan 4, 81-83, 160,600, 601
switchport mode trunk
switchport nonegotiate
channel-group 23 mode on
spanning-tree portfast trunk
int TenGigabitEthernet6/5
int port-channel23
switchport
switchport trunk allowed vlan 4, 81-83. 160,600,601
The VM servers belong to vlan 4.
The issue here is on one, Port-channel, I'm unable to reach the IP assigned to the VM, from HQ. It's available over the LAN, but not across, the wire. Now the interesting thing is, if I remove a port from the channel, I can reach it.
I've comparted the configs and all looks good, and compared the settings on the VM's nothing stands out. This feels like a bug, but lost here, any suggestions would be appreciated.
Thansk
Reza Sharifi
It could be a bug,
A couple of suggestions,
1-can you delete the Portchannel completely and rebuild it again?
2-If that does not work, can you delete the Portchannel and rebuild it with a new po number?
How other Portchannels are connected to VMS and are working with no issues?
Hi Reeza,
Thanks, I tried rebuilding the Port-Channels, no luck there, same behavior.
They are connected to the VM's the same, but issues are there, one I just discovered, this morning.
On the other connections, I can ping, from our core to the VM addresses, but from my pc, they drop. If I kill one of the interfaces that are on the port-channel, then I can ping from my PC and the local core.
I agree, it's very buggy behavior, very unusual.
Seems like a load balancing issue. Can you try matching the switch load balancing criteria to the VM. I think the VMs are by default source ip. Also, for testing, you may want to change one of the Portchannel protocol from on on to LACP and see if it changes anything.
Guy, its sounds like a promiscous mode on vm.
Check this link and try it: https://kb.vmware.com/s/article/1004099
obs: do it on host that you having problem.
Jaderson Pessoa
*** Rate All Helpful Responses ***
