4500 stuck in IOS loading
Hi everyone,
I  have some issue with a WS-X45-SUP7L-E sup card on WS-C4503-E.
This one is stuck in loading IOS (cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin) with this message :
loading image
Checking digital signature
bootflash:/cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin: Digitally Signed Release Software with key version A
Rommon reg: 0x00004F80
Reset2Reg: 0x00000F00
Image load status: 0x00000000
Winter 110 controller 0x04688FA8..0x047F230F Size:0x002FDB9D Program Done!
[  171.856830] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
01)
And nothing after this message.
No FAN or PSU error.
I've try to erase the config and bootvar without any success:
rommon 1 >set
 PS1=rommon ! >
 ConfigReg=0x0102
 RommonVer=15.0(1r)SG3
 SupportedFeatures=1
 BootedFileName=flash1:/USER/cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin
rommon 2 >version
 Primary Rom Monitor Version 15.0(1r)SG3
 Compiled Mon 29-Aug-11 12:09 by andrao-k10rommon-150_1r_SG3
 Supervisor: WS-X45-SUP7L-E  Chassis: WS-C4503-E
 CPU Rev: 2.2, Board Rev: 4, Board Type: 105
 CPLD Lobot Rev: 7.0x35c0.0x1375 Installed memory: 2048 MBytes
rommon 3 >dir bootflash:
 Date       Time    Attribute   Size         Name
 2017/11/03 07:52   -rw-rw-rw-        8096   startup-config.saved_vs-20171103-075255
 2017/03/13 09:33   -rw-rw-rw-   171853028   cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin
 2017/03/20 09:03   -rw-rw-rw-   178987612   cat4500e-universalk9.SPA.03.06.06.E.152-2.E6.bin
   Total space =    798175 KB
   Available   =    458560 KB
rommon 4 >boot bootflash:cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin
loading image
[  171.856843] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
I tryed to boot on cat4500e-universalk9.SPA.03.06.06.E.152-2.E6.bin but I have the same issue.
This card was previously in VSS (before the erase config, I do not know if it's a coincidence). The VSS peer is OK. I switched the 2 sup card without any success.
Have you some idea to solve this ?
Thank you a lot for your suggestions.
CMA
Deepak Kumar
This is IOS bug ID CSCue15724.
Please refer the following link:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCue15724/?referring_site=bugquickviewredir
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Kumar,
Tank you for replying.
I have check this bug and so I tryed to load another IOS, but I have the same issue :
rommon 2 >set interface fa1 192.168.1.2 255.255.255.0
rommon 3 >set ip route default 192.168.1.1
rommon 4 >set
 PS1=rommon ! >
 ConfigReg=0x0102
 SupportedFeatures=1
 BootedFileName=bootflash:cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin
 IpAddr=192.168.1.2
 Netmask=255.255.255.0
 Broadcast=192.168.1.255
 Gateway=192.168.1.1
rommon 5 >
 Established physical link 1Gb Full Duplex
 Network layer connectivity may take a few seconds
rommon 5 >ping 192.168.1.1
 Host 192.168.1.1  is alive
rommon 6 >boot tftp://192.168.1.1/cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin
 Tftp Session details are ....
 Filename     : /cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin
 IP Address   : 192.168.1.2
 Loading from TftpServer: 192.168.1.1
 Received data packet # 349513
 Loaded 178950332 bytes successfully.
/cat4500e-universalk9.SPA.03.06.07.E.152-2.E7.bin: Digitally Signed Release Software with key version A
 Winter 110 controller 0x0468ADD8..0x047F413F Size:0x002FDB9D
 Program Done!
[   0.058385] pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
And stay stuck after this last message.
I have no more idea to solve this...
