07-10-2016 09:12 PM - edited 03-08-2019 06:34 AM
Hi all,
I've been searching for long related with 4500E Supervisor Engine 8-E Uplinks port mode. Is there any specific command to configure the port mode between 1 GE and 10 GE?
Or, inserting SFP will make it 1G, inserting SFP+ will make it 10GE?
How about the configuration? as we know , 1GE port is shown as 'interface GigabitethernetX/X'. If I change the transceiver from SFP to SFP+, will the configuration disappear? Or, only the interface name will be updated to 'interface TenGigabitethernetX/X' ?
07-10-2016 10:33 PM
It is all based on the SFP.
Insert 1Gig SFP will make it 1G, insert SFP+ will make it 10GE.
The name will not change. If I remember correctly even after you inset the SFP (1Gig) the port will still show as 10G. All 8 ports are 1/10G.
03-06-2018 06:58 AM
03-06-2018 06:49 AM
Hello JIAQI,
4500E Supervisor Engine 8-E Uplinks 1GE/10GE Mode
You can refer the link below . https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/25sg/configuration/guide/conf/sw_int.html
