I recently got two 4500X boxes I'm trying to get going in the lab. It seems that getting management working is biggest challenge. The preinstalled IOS XE was cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin witch works great. No issues so far.
I want to upgrade to 03.05.0x to take advantage of the new fast hello functionallity avoiding the use of PAgP. After upgrade the POST seems to break and prints the somewhat documented message
No Mountpoints DefinedJan 17 09:48:14 %IOSXE-3-PLATFORM: process sshd[5241]: error: Bind to port
I can for the love of it not get any traffic working for the Fa1 interface with 03.05.01 running. I have no tried 03.05.00.
This message does not print on the 03.04.02 version and traffic works as expected over Fa1.
I can't seem to find any solid leads on this being a bug, but it sounds like a bug, it acts like a bug; It has to be a bug. I've read about bugs affecting L3 interfaces in 03.04.0x, but since its documented fixed in at least 03.04.02 and I can't provoke the same behaviour there, I don't know. Can't find anything about this for 03.05.01.
Anyone running 3.5.1 or maybe 3.5.0 not having issues with this?
Thanks in advance
conf t
ip tftp source f1
end
I have also tried to upgrade from 3.4.2 to 3.5.1
After that , some "old" terminals become unpingable from my pc
Packet capture on my pc's switch shows erroneous dest mac address in icmp reply
I am unable to explain this phenomena, so I decided to downgrade to Ios Xe 3.4.3
And problem is solved
Anybody observed this ?
Release notes don't say anything
I am using etherchannels on L2 switches between source and destination, could it help ?
Why some terminals are impacted not others in same vlan ?
Alain
This issue has been resolved in cat4500e-universalk9.SPA.03.06.00.E.152-2.E.bin
Fa1 now works in VSS mode.
