4500X dot1q subinterfaces
jtrohm
Level 2
Level 2
I have a unique situation where I am running multiple q-in-q metro networks and would like to do layer 3 VRFs in standalone tags WITHOUT creating a vlan on the switch.
What I'd like to do is something like the following:
interface ten 1/1/1
 description Metro Production Network
 no switchport
 ip address 10.1.1.1 255.255.255.0
interface ten 1/1/1.901
 description Metro Isolated Network
 ip vrf forwarding Isolated
 encapsulation dot1q 901
The end game is to be able to backhaul public Internet and Lab networks in a routable way without wasting Vlan numbers or dealing with overlapping vlans between metro providers.
What I'm running into is that my 4500X doesn't seem to take a sub-interface number when I try to configure it. The command is there, but it fails. Example:
 MYSW1(config)#int tenGigabitEthernet 1/1/1.901
 % Invalid input detected at '^' marker.
Thoughts?
Richard Burts
I believe that what you are attempting to do with sub interfaces is not supported on this platform. And I am not sure that I really understand what you are trying to accomplish with this. What would interface ten1/1/1 connect to? Your explanation seems to indicate that you do not want to create a vlan on the switch. But this
essentially creates vlan 901.
Rick
Rick
Rick
Thanks Rick.
It's more a cleanliness thing. Creating a subinterface with a dot1q tag doesn't create a vlan on the switch. It only allows the switch's port to act as a client on an external tagged vlan. I suspect you are right about the non-supported nature of this, but I want someone with a cisco.com e-mail address to confirm that and also confirm that the help commands show subinterfaces as valid (which I am sure is just lazy programming) before I give up.
MYSW1(config)#int ten 2/1/29.?
  <0-4294967295>  TenGigabitEthernet interface number
MYSW1(config)#int ten 2/1/29.55
I can accomplish the same thing with VLANs, but if I create overlapping VLAN numbers between metro carriers, it gets messy.
