4500X Licensing
james.a.kramer3
Community Member
I purchased some 4500X switches with entservices licensing, but I'm a bit perplexed by the output of show license all. It looks to me like they shipped with a trial version rather than a permanent license. I'm not familiar with activating/upgrading licensing, so I'd love some help interpreting the output or some assistance with the process to ensure my entservices license is activated permanently.
Switch#show license all
License Store: Primary License Storage
StoreIndex: 0 Feature: ipbase Version: 1.0
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
License Store: Dynamic License Storage
StoreIndex: 0 Feature: entservices Version: 1.0
License Type: Evaluation
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
License State: Active, Not in Use, EULA not accepted
License Priority: None
StoreIndex: 1 Feature: entservices Version: 1.0
License Type: PermanentRightToUse
License State: Inactive
StoreIndex: 2 Feature: ipbase Version: 1.0
StoreIndex: 3 Feature: ipbase Version: 1.0
StoreIndex: 4 Feature: lanbase Version: 1.0
Reza Sharifi
Can you post the output of "sh ver"?
It should show you the license level installed.
If you don't see:
 License Level: entservices   Type: Permanent
Than try the following:
Do a "sh bootflash" and you may see the license there, if you do run the "license install ...." command to install it.  You have to reboot for it to take effect.
Reza Sharifi
If you don't see:
show version confirms it's just running ipbase.
License Information for 'WS-C4500X-32'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
I don't see license files on any of my filesystems, so I guess it's time to contact my vendor?
Yes, I would contact them since the file is not there.  Also, sometimes they send it via email or an envelop in the box.
Hi Reza,
Sorry to jump on an old post but I've just read this and found it very useful. I'm trying to get EIGRP working on a 4500X-VSS cluster. Having done the licence right-to-use entservices accepteula it appears that the licence (hardware was purchases with entservices) is running correctly.
Following the show version command you mentioned I can see the following.
License Level: entservices Type: Permanent Right-To-Use
Next reboot license Level: entservices
My questions is, do you need to do anything on the non-active vss member in regards to licences, or does the licence command take affect across the whole configuration. I have seen other posts where people reboot a vss cluster and then get boot errors and can't re-establish VSS due to a licence mis-match.
I'm hoping the licence side of things is OK, and then I just need to troubleshoot the eigrp part of things.
Many Thanks
Jon
