07-25-2007 07:31 PM - edited 03-05-2019 05:30 PM
Hello!
Our Cisco 4503 always when reboots comes to the rommon, but we neet it to boot IOS automatically. Configuration register is 0x102, but it doesn't help. We configured "boot system flash cat4000-i9s-mz.122-25.EWA4.bin", where "boot system flash cat4000-i9s-mz.122-25.EWA4.bin" is the default and the only IOS on flash. But it also doesn't help!
Could you tell me what to pay attention to to understand the problem, and help to make the 4503 to boot automatically?...
07-25-2007 08:48 PM
You are using a wrong bootvariable.
Please set the boo variable gto following:
Switch#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#boot system flash bootflash:cat4000-i9s-mz.122-25.EWA4.bin
You should be all set to go fine after this.
HTH,Please rate if it does.
-amit singh
07-30-2007 08:34 PM
Thanks asingh2!
I'll rate this post after I'll check this. Now we can't reboot the Cisco...
