4506 Backplane
saquib.tandel
How do i check the Backplane utilization for each slot on a Cisco Catalyst 4506.
ST
Fabienne Stephanoff
Unfortunately there is no such command available to check backplane
utilization on this platform. There was bug that was open for the same issue
CSCdy14666
-  Need a CLI command to display backplane traffic in CAT4xxx
IOS. The
CSCdy14666
Bug is closed as this is a feature enhancement that we
do not have the resources to implement at this point.
You can use other commands on this platform to measure or troubleshoot
performance relate issues:
- show platform              <-- Various sub commands to check various sub systems
- show processes cpu    <-- Used to see current CPU utilization
- show interface              <-- Used to check for input/output drops and any other interface errors.
- show memory              <-- Used to check free/used memory
You can also refer to the master datasheet link for Cisco Catalyst 4500
Series Switches (includes supervisor and line modules) for more performance
specific information. These links also provides chart would give you the
comparison between supervisors and their backplane utilization performance:
Data Sheets
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheets_list.html
Hope this helps.
Fabienne.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Since the 4500 series chassis and supervisors have known maximum values of bandwidth per slot (6, 24 or 48 GB/slot), the aggregate bandwidth for all the ports on a single line card would indicate the bandwidth utilization being used for that slot.
You are likely hitting the following bugs
CSCee30742
Need an SNMP Object for monitoring the following in Catalyst 4000s (IOS):
- Backplane utilization (total)
- L2 Fwd Low
CSCdy14666.
There was an enhancement request filed before on having such a function on cat4k, but bug was closed
due to amount of resource required.
However, the Catalyst 4000 (IOS) does not support CISCO-STACK-MIB.
Therefore, it is not possible to monitor backplane utilization on the Cat4000 IOS via SNMP.
can you try show platform chassis & show system commands
For the Layer 2 Drops, the information is already available via the CLI 'show platform cpupacketman' or 'show platform cpu packet driver' commands
Hope this helps.
-Somu Jayaraman
Rate this answer if it was helpful
