4506-e with sup8 in vss need qos config for voip
SirEna
hi,
i have 4506-e with sup8 running in vss mode and i needed to make sure voip traffic is preserved and prioritize.
network set-up:
cisco phone---->2960-x----->etherchannel-->>4506-e
auto qos is already configured in 2960 switches and as what i understand so far, qos is already enabled on 4506 by default and its ports are already trusted but not sure whether additional config is needed for 4506 in the above set-up?
i come across this docu http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-6-0E/15-22E/configuration/guide/xe-360-config/qos_mrg.html#91778
but under configuring vss auto-qos, its not clear to me whether those configuration lines mentioned should be manually configured or there is a command that can trigger them to be populated on the switch?
globally, i can see qos srnd command, but after i executed nothing happens.
under interface configuration, below are the commands i can see available for qos:
VSS(config-if)#qos trust device ?
  cisco-phone   Cisco IP Phone
  cts           Cisco-telepresence
  ip-camera     Cisco video surveillance camera
  media-player  Cisco Digital Media Player
any suggestions suggestions is greatly appreciated. tia.
SirEna
wow thanks a lot for all replies o_O
