4506 High CPU
ckuriyar74
I have recently installed catalyst 4506 and configured as L2 switch.
But sometimes the CPU load reaches 99% and when i see the PM callback process takes more cpu load.
I hve attached the config file along with show process details.
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA9, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 21-Mar-07 11:35 by tinhuang
Image text-base: 0x10000000, data-base: 0x114B64F4
ROM: 12.2(31r)SG2
Dagobah Revision 226, Swamp Revision 34
4506-018 uptime is 3 days, 19 hours, 34 minutes
System restarted at 15:25:24 UTC Sat Jun 9 2007
System image file is "bootflash:cat4000-i9s-mz.122-25.EWA9.bin"
cisco WS-C4506 (MPC8245) processor (revision 10) with 262144K bytes of memory.
Processor board ID FOX111110JX
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from PowerUp
2 Virtual Ethernet interfaces
240 FastEthernet interfaces
2 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Any one can suggest solution for this?
ckuriyar74
I resolved the problem and now the CPU utilization is avg 30%
What was the problem?
