4507-E+R switch, which sup
carl_townshend
Hi All
Im looking at purchasing 2 4507 switches to run VSS
Should I be looking at the Sup-8 or Sup-7
I see the 8 has wireless functionality, however I will not be using this, Its for a collapsed core deployment with about 2500 devices on site.
cheers
ageralde
Hi carl_townsend,
Since you are not looking for the wireless functionality of the Supervisor engine 8, then yes, you may consider  the Supervisor Engine 7 (http://cs.co/9008ciZn). Do you have any specific requirement for the supervisor engine? Feel free to message me directly for further assistance. Hope this helps!:)
Angela (ageralde@cisco.com)
