EPC3208 keeps resetting for no reason and in no pattern.
I have the following problem, every now and then my EPC3208 is disconnecting and coming back online. I have not found any answer to this even after 5+ support people from my internet provider ( UPC Romania ) have come and changed all the possible cables.
My downstream channels and SNR are as the following:
 Power Level:Signal to Noise Ratio:
Channel 1:1.4 dBmV43.1 dB
Channel 2:1.1 dBmV41.5 dB
Channel 3:1.8 dBmV43.1 dB
Channel 4:2.6 dBmV40.9 dB
Channel 5:2.9 dBmV43.0 dB
Channel 6:3.1 dBmV43.2 dB
Channel 7:3.2 dBmV43.1 dB
Channel 8:2.8 dBmV41.4 dB
The upstream channels are:
 Power Level:
Channel 1:57.0 dBmV
Channel 2:0.0 dBmV
Channel 3:0.0 dBmV
Channel 4:0.0 dBmV
This is going impossible to bear while playing online games because of the random disconnects.
Please suggest a solution beside swapping the modem with a new one ( they have done that ), swapping the cables ( they have done that ) and changing the power outlet ( I have done that)
0 Replies 0
