4507 FAN sensor error
naitikpatel
I have 4507 switch and I got the error of fan sensor which is mention below
Power        Fan             Inline
Supply  Model No                     Type                    Status          Sensor         Status
PS1     PWR-C45-1400AC    AC 1400W                bad/off         bad/off           n.a.
PS2     PWR-C45-1400AC    AC 1400W                good             bad/off           n.a.
What the meaning of FAN Sensor both are Bad/off ?
Prasan Venky
Level 3
Level 3
it seems to be a hardware problem and would require replacement to resolve this issue.
Means  which Hardware problem........Fan problem ? Power slot problem ?     any specific  hardware ........?
In power supply also fan will be present. Anyways replacement would be for power supply only.
InayathUlla Sharieff
Hi Naitik,
Power supply—Includes the power supplies and power supply fans. If you suspect problems with the power supplies.
To help isolate a power subsystem problem, follow these steps:
Step 1 Check  whether the power supply LED labeled GOOD is on or the LED labeled FAIL  is on. (on the DC multi-input power supply, the LEDs are labeled INPUT  1, 2, or 3 or OUTPUT FAIL.)
Step 2 If the LED labeled GOOD is off or if the LED labeled FAIL is on, take the following steps:
Ensure that the power supply is flush with the back of the chassis.
Unplug  the power cord, loosen and reinstall the power supply, tighten the  captive installation screws, and then plug in the power cord.
Step 3 If  the LED labeled GOOD remains off, there might be a problem with the AC  source or the power cable. Connect the power cord to another power  source if one is available.
Step 4 If the LED labeled GOOD fails to light after you connect the power supply to a new power source, replace the power cord.
Note If this unit has more than one power cord, repeat Step 1 through Step 4 for each power input.
Step 5 If  the LED labeled GOOD still fails to light when the switch is connected  to a different power source with a new power cord, the power supply is  probably faulty. Replace the power supply.
Step 6 If  the LED labeled FAN OK fails to light when the switch is connected to a  power source with a known good power cord, there is a malfunction in  the fan that cools the power supply. Replace the power supply.
Step 7 If a second power supply is available, install it in the second power supply bay.
Step 8 Check that the LED labeled GOOD is on for the additional power supply. Check that the LED labeled FAIL is off.
Step 9 If the LEDs are not on, repeat the previous procedure to troubleshoot the second power supply.
If you are unable to resolve the problem, or if you determine that  either a power supply or backplane connector is faulty, contact the  Cisco Technical Assistance Center (TAC) for instructions.
In your situation go ahead and RMA the PSU.
Inayath
*Plz rate all usefull posts.
