4507 Switch - Inactive Interfaces
luissoler79
Community Member
I have a 4507 switch with the following:
IOS ver cat4500-entservicesk9-mz.122-52.SG
Sup- WS-X4516-10GE
There are interfaces on the sup card that have a status of "inactive". How can I activate these interfaces? The #hw-module uplink select all command is not there!
5 Replies 5
iyde
Level 8
Level 8
Hi.
Either the VLAN assigned to these interfaces are not created in the VLAN database. Or there might be something with the number of ports supported - could you post a show module and show interface status?
HTH, Ingolf
luissoler79
Community Member
Below are the requested outputs. Thanks for the help!
#sh module
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE1242XV6E
3 6 Sup V-10GE 10GE (X2), 1000BaseX (SFP) WS-X4516-10GE JAE1239W7KQ
4 6 Sup V-10GE 10GE (X2), 1000BaseX (SFP) WS-X4516-10GE JAE1239W437
M MAC addresses Hw Fw Sw Status
1 0023.5e6d.a5c0 to 0023.5e6d.a5ef 2.5 Ok
3 0023.33ca.d680 to 0023.33ca.d685 5.1 12.2(31r)SGA 12.2(52)SG Ok
4 0023.33ca.d686 to 0023.33ca.d68b 5.1 12.2(31r)SGA 12.2(52)SG Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor SSO Active
4 Standby Supervisor SSO Standby hot
#sh int status
Port Status Vlan Duplex Speed Type
Te3/1 connect 9 full 10G No X2
Te3/2 inactive 9 full 10G No X2
Gi3/3 connected 316 full 1000 1000BaseLH
Gi3/4 connected trunk full 1000 1000BaseLH
Gi3/5 inactive 9 full 1000 No Gbic
Gi3/6 inactive 9 full 1000 No Gbic
Te4/1 notconnect 1 full 10G No X2
Te4/2 inactive 1 full 10G No X2
Gi4/3 notconnect 1 full 1000 No Gbic
Gi4/4 connected trunk full 1000 1000BaseLH
Gi4/5 inactive 1 full 1000 No Gbic
Gi4/6 inactive 1 full 1000 No Gbic
Put gbics in the ports..
Thanks for the suggestion, I had tried that already. Unfortunately it did not resolve the problem.
rriquier
Frequent Visitor
Frequent Visitor
Hello, due to the fact you are using a redundant supervisor, some interfaces are disabled
. This is a normal behavior.
You can find on datasheet which combinations are possible
(http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps9294/product_data_sheet0900aecd806df543_ps4324_Products_Data_Sheet.html)
Table 4. Supervisor Engine 6-E  High-Availability and Uplink Options
Feature and Description
Redundant Capable
• Yes
• Cisco Catalyst 4507R or 4507R-E model
• Cisco Catalyst 4510R or 4510R-E model
Active  Supervisor-Engine Uplinks in Redundant Mode
• Two 10 Gigabit Ethernet (wire-speed)
or
• Four 10 Gigabit Ethernet (2:1 oversubscribed)*
or
• Four Gigabit Ethernet (Cisco Twin Gig Converter  Module)
or
• Eight Gigabit Ethernet (Cisco Twin Gig  Converter Module)*
or
• One 10 Gigabit Ethernet and Two Gigabit  Ethernet each supervisor-engine*
Active  Supervisor-Engine Uplinks (Nonredundant Mode)
or
• One 10 Gigabit Ethernet and 2 Gigabit Ethernet  (Cisco Twin Gig Converter Module)
or
Uplink Optic Types
SFP (Gigabit Ethernet)  with Cisco Twin Gig Converter Module or X2 optics (10 Gigabit Ethernet  ports)
SSO/NSF and ISSU
Yes
