4507 upgrade problem
mirek.tichy_2
Level 3
Level 3
Anybody saw this problem?
Cat 4507 Sup IV is currently running cat4000-i5k2s-mz.121-20.EW1.bin
I have copied newer image (tried more ones for example cat4000-i5s-mz.122-25.EWA14.bin).
After reload there could be seen a succesfull FPGA image upgrade.
But the switch failed boot the new image with an "image corupt" message.
I tried more 12.2 images, I tried perform "verify" command, bootrom vas upgraded to 122_31r_SGA4
Many thanks for help
Mirek
* FPGA Upgrade Utility For  WS-X4515 System              *
* Copyright (c) 1997-2004 by Cisco Systems, Inc.         *
* All rights reserved.                                   *
Image size = 831.1008 KBytes
Maximum allowed size = 1023.75 KBytes
Upgrading your FPGA image... DO NOT RESET the system
unless instructed or upgrade of FPGA will fail !!!
Beginning erase of 0x100000 bytes at offset 0x3d00000...  Done!
Beginning write of fpga image  (0xcfff0 bytes at offset 0x3d00000)...
This could take as little as 30 seconds or up to 2 minutes.
Please DO NOT RESET!
Success! FPGA image has been upgraded successfully.
System will reset itself and reboot within few sec
* Welcome to Rom Monitor for      WS-X4515 System.       *
* Copyright (c) 2003-2007 by Cisco Systems, Inc.         *
Rom Monitor Program Version 12.2(31r)SGA4
Supervisor: WS-X4515  Chassis: WS-C4507R
Hardware Revisions - Board: 2.7 CPLD: 28 Dagobah: 95
MAC Address  : 00-0d-bd-60-7c-2c
Ip Address   : Not set.
Netmask      : Not set.
Gateway      : Not set.
TftpServer   : Not set.
Main Memory  : 512 MBytes
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x2102
Rommon reg: 0x5F004380
Decompressed 8169455 bytes, expected 8333872 bytes, image corrupt
POST image corrupt, reloading
Resetting...
vvasisth
Level 6
Level 6
format the flash then copy the IOS and change the boot variable.
This should fix the problem.
Varun
