4507 went into romon
mahesh18
Level 6
Level 6
                   hi all,
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method,  type 'confreg' command.
rommon 1 >set
PS1=rommon ! >
RommonVer=15.0(1r)SG5
SupportedFeatures=1
ConsecPostPassedCnt=2
DiagMonitorAction=Normal
CONFIG_FILE=bootflash:cat4500e-universalk9.SPA.03.02.04.SG.150-2.SG4.bin
RET_2_RTS=03:00:52 MDT Tue Jun 5 2012
RET_2_RCALTS=1338886852
BootedFileName=bootflash:cat4500e-universalk9.SPA.03.02.04.SG.150-2.SG4.bin
ConfigReg=0xe542
Need help thanks
mahesh
2 Accepted Solutions
Ivan Shirshin
When booting in ROMMON, do the following:
     confreg 0x2102
     dir bootflash:
Check the IOS files there and boot manually:
     boot bootflash:
E.g.:
     boot bootflash:cat4500e-universalk9.SPA.03.02.04.SG.150-2.SG4.bin
When in IOS, check the boot string to point to correct file name:
     show boot
     show run | i boot
If it is incorrect, remove it and add a correct one:
     conf t
          no boot .....
          boot ....
          end
     wr
Check again to make sure there are only correct entries now:
     show boot
     show run | i boot
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Mahesh,
Can you try using an SD card to copy the IOS into it?  It's alot faster and less hassle.
12 Replies 12
mahesh18
Level 6
Level 6
Here is IOS which i download to switch
rommon 7 >dir bootflash:
Date       Time    Attribute   Size         Name
2012/06/05 09:00   -rw-rw-rw-       47973   cat4500e-universalk9.SPA.03.02.04.S
G.150-2.SG4.bin
   Total space =    808548 KB
   Available   =    811872 KB
mon 1 > on choosing a boot method,  type 'confreg' command.
rommon 1 >boot bootflash:cat4500e-universalk9.SPA.03.02.04.SG.150-2.SG4.bin
File has bad file magic number:      0x0. Is it a valid file?
boot: can not load "bootflash:cat4500e-universalk9.SPA.03.02.04.SG.150-2.SG4.bi
n"
rommon 2 >
n"
rommon 2 >
See ythe steps I posted below. I see you tried manual boot already and it reported "File has bad file magic number".
This error typically indicates the file is corrupted, I suggest to download it again from cisco.com and re-upload on the switch.
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan,
tried to copy file from tftp
rommon 53 >boot tftp://169.254.215.131/cat4500e-universalk9.SPA.03.02.04.SG.150-
2.SG4.bin
Tftp Session details are ....
Filename     : /cat4500e-universalk9.SPA.03.02.04.SG.150-2.SG4.bin
IP Address   : 169.254.215.135
Loading from TftpServer: 169.254.215.131
Tftp session failed: File not found
The FTP server should be accessible from the management port. Did you do a ping to confirm server is reachable?
     ping <tftp_server_ip_address>
If it reachable, than check whether the file is located in the default FTP server directory as you are specifying in the ftp url string.
Please check if you followed all steps specified in the procedure (option 2) in this guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_24727.html#wp289935
Kind Regards,
Ivan
Kind Regards,
Ivan
It booted fine now
now this issue
Switch#copy tftp: bootflash:?
% Unrecognized command
Address or name of remote host [169.254.215.131]?
Source filename [cat4500e-universalk9.SPA.03.02.04.SG.150-2]?
Destination filename [cat4500e-universalk9.SPA.03.02.04.SG.150-2]?
Accessing tftp://169.254.215.131/cat4500e-universalk9.SPA.03.02.04.SG.150-2...
%Error opening tftp://169.254.215.131/cat4500e-universalk9.SPA.03.02.04.SG.150-2
(Socket error) Switch#copy tftp: bootflash:?
(Socket error)
mahesh
Do you have any IP configured on your switch? Can you ping the FTP server when booted in IOS?
Try the following:
1. Configure vlan 1 on switch and assign a port facing FTP server to that vlan.
2. Create IP on vlan in the same subnet as server.
3. Try to ping and if it does then you are all good.
4. Check that there is no password on FTP server.
5. Start download now.
Kind Regards,
Ivan
Ivan Shirshin
     confreg 0x2102
     dir bootflash:
     boot bootflash:
E.g.:
     show boot
     show run | i boot
     conf t
          no boot .....
          boot ....
          end
     wr
     show boot
     show run | i boot
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan,
i tried see the posts
did not work
thanks
mahesh
Hi Mahesh,
Hi Ivan and leolaohoo,
Issue was that Management port on 4507 works only for ROM ON mode to boot pc from tftp.
When i try to run command copy tftp bootflash it did not worked.
Then i connected my pc to port on lince card 1 then copy tftp bootflash worked.
Thanks for you help
Mahesh
Mine is a 4503, Supervisor 6-E. Your answer was quite helpful guiding me to the solution the worked for me when updating my other switches - deleting prior files on bootflash: (images, vlan.dat and config files).
I got the following when I just re-pointed the "boot system flash..."only:
Autobooting using the first file from bootflash.....
boot: can not load "bootflash:"
Autoboot using first file from bootflash failed.
rommon 1 >
Here are the steps I applied after my first experience:
rommon 1 >boot bootflash:........................... (newly uploaded image name.bin)
Then from IOS:
show bootflash:
delete bootflash:.........................(old image name)
Do this for other files not required but seen on bootflash.
show run | i boot
delete boot system flash bootflash:....................... (old image name)
conf t
boot system flash bootflash:............................(new image name)
end
That resulted in a normal reboot with the new image for me! Thanks a lot for your post.
