4507R process utilization high
Hi  ,
Any one can help to dig high cpu issue on 4507R switch .Logs are attached -
I m going thru cisco doc , it says to SPAN cpu , I yet to do it .but apart form this if any one get something pleae post me .
IAN WHITMORE
Level 4
Level 4
Have you been through this document?
http://www.cisco.com/en/US/customer/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
Also, SSH process appears to be high. This could be due to someone issuing a show tech (like yourself to get the output) or if you have some debug enabled (check your sh debug). Make sure you have a timeout configured on your SSH sessions as well.
As for the other Mgmt HiPri and LowPri, there are some good indications in the document referenced above.
HTH,
Ian
