4507R to SSG 140
amar007inus
Here i have a two cisco4507R switches and configured with VLANs..Here need to connect cisco4507R switches to juniper SSG 140 firewall with individual cables.can anybody help in configuration at Juniper side..Here I am not supposed to ask this question..Coz it is combined of both firewall and ciscoswitches,,thts y i am asking..
Amar.
Collin Clark
Do you want the SSG to be the layer 3 gateway of the 4507 vlans? What exactly is your question?
Yes,,i want to use SSG as a gateway to the switches...And here the one 4507R is connected to ethernet port on SSG,And also 2nd 4507R is connected to other ethernet port on the SSG...i want to know the configuration at SSG...and routing to out side..
Amar.
You can either trunk or you could assign each physical port as the gateway (just like Cisco).
Here's the link to configure the SSG.
http://www.juniper.net/techpubs/software/screenos/screenos6.0.0/index.html
PS Use the webUI for configuration (easier for first time users).
HTH and please rate.
