4510 Switch Question
mpozorski
Level 4
Level 4
Greetings - Does anybody know if the modules on a 4510 are both hot-swappable and plug and play?  We have some 4510's and have found that we need to add new modules to get more available ports.  I just need to know if I will need to shut the switch down before I install the new modules into the switches or if I can just plug in the new 48 port module and be able to configure the ports without a restart.
Collin Clark
Yes they are hot-pluggable.
Cisco will donate $1 to the Red Cross Haiti fund for every rated post!
https://supportforums.cisco.com/docs/DOC-8727
http://www.joomlatabs.com/thermometer/thermo.php?max=10000&current=290&var=lt&color=red
mpozorski
Level 4
Level 4
Thank you for the information Collin.  I was a little concerned with the idea of having to take the switch down to add another module.
It goes without saying though that I would recommend doing it during a down time or maintenance period. In case mumphrey decides to show up.
