4510R warning...
Rafael Jimenez
Level 4
Level 4
What means this?...
ep 20 07:56:33.615: %C4K_ETHPORTMAN-3-TENGIGSEEPROMREADFAILED: Failed to read seeprom on port Te5/1. If an X2 module is installed, remove and reinsert the X2. If a TwinGigConverter is installed, configure the port group for GigabitEthernet.
Im using Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(46)SG, RELEASE SOFTWARE (fc1).
Thanks.
So what does the port look like now? Can you install a total of 4 SFP's in to each sup?
sdrossen2
Do you have 10Gb or TwinGig converter? I am going to assume twingig so you'll need to run the command:
hw-module module 5 port-group 1 select gigabitethernet
but to match your specific setup.
I don't have any converter installed.
i seeing a Unknow port in the show commands, see bellow:
*Sep 27 08:19:33.323: %C4K_ETHPORTMAN-3-TENGIGSEEPROMREADFAILED: Failed to read seeprom on port Te5/1. If an X2 module is installed, remove and reinsert the X2. If a TwinGigConverter is installed, configure the port group for GigabitEthernet.
*Sep 27 08:19:37.139: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Sep 27 08:19:38.879: %C4K_ETHPORTMAN-3-TENGIGSEEPROMREADFAILED: Failed to read seeprom on port Te5/2. If an X2 module is installed, remove and reinsert the X2. If a TwinGigConverter is installed, configure the port group for GigabitEthernet.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(46)SG, RELEASE SOFTWARE (fc1)
Phoenix#show hw-module module 5 port-group 1
Module Port-group Active Inactive
5 1 Te5/1 Gi5/3-4
Phoenix#show hw-module module 5 port-group 2
5 2 Gi5/5-6 Te5/2
Phoenix#show int status mod 5
Port Name Status Vlan Duplex Speed Type
Te5/1 notconnect 1 full 10G Unknown X2
Te5/2 inactive 1 full 10G No X2
Gi5/3 inactive 1 full 1000 No Gbic
Gi5/4 inactive 1 full 1000 No Gbic
Gi5/5 notconnect 1 full 1000 No Gbic
Gi5/6 notconnect 1 full 1000 No Gbic
