4900M doesn't have LACP command options
brojas
I have a 4900M running entservices version of 15.1(2)SG7, I'm attempting to test some of the LACP features but I don't see the lacp options under the interface commands. Am I missing something to activate these commands?
7 Replies 7
Philip D'Ath
The issue I'm facing is a bit different, I can get the port-channel up but would like to set two as active and one on standby. So looking for the lacp max-bundle and lacp fast-switchover commands but they are not present as options under the port-channel interface.
Actually 8 is the limit on this box. Also max-bundle command is not yet available on 4500 platforms.
Thank you!
From the documentation its appears to be supported, its disappointing that is not clearly stated. Is this a hardware limitation for support for standby links?
Appreciate the responses.
I personally think it is a software limitation.
Thanks for the feedback.
Oh, a standby link.  I have had that exact issue before.  Yes, it is not supported and a pain.
